Brake help!
Old Apr 6, 2010 | 11:30 AM
The Bull's Avatar
The Bull
Default Brake help!
i am in the middle of doing my brakes for the first time. I cant get the new pads around the rotor what do i have to do?
Old Apr 6, 2010 | 12:14 PM
stenerson's Avatar
stenerson
Did you compress the piston?
Old Apr 6, 2010 | 12:45 PM
caliboy@heart's Avatar
caliboy@heart
use a c clamp and compress both the pistons...use the old pad as the plate to do it evenly on both pistons.
Old Apr 6, 2010 | 12:48 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
And where in GA are you at?
Old Apr 6, 2010 | 01:22 PM
BadHab1t's Avatar
BadHab1t
i always pull the cover off my fluid res and put a baggie over it so its a lil easier and the baggie prevents spray...never had it bleed it either that way but i never touch the pedal either during a break job...
Old Apr 6, 2010 | 01:35 PM
The Bull's Avatar
The Bull
20 miles north of ATL
Old Apr 6, 2010 | 09:41 PM
The Bull's Avatar
The Bull
well i got the brakes done not to hard but they are squeekin pretty bad any ideas?
Old Apr 6, 2010 | 11:57 PM
BlakeCP29's Avatar
BlakeCP29
shoulda sprayed some brake disc quiet on the pads when you were about to put them on. always use it and never had a squeak. bought a used car w/ new pads and annoying squeak ( sold the POS after a few months, it was a bad buy) making me further believe the brake disc quiet spray really works well
Old Apr 7, 2010 | 12:02 AM
rocket23's Avatar
rocket23
any chance of spraying that stuff on the back side w/out hitting the rotor? I have an annoying squeal on the rear pass side.( new brks and rotors btw)
Old Apr 7, 2010 | 12:13 AM
The Bull's Avatar
The Bull
ok ill give that a shot tomorrow. did any of yall have a problem with the pad sliding around alot on the runners they lay on?
