leveling kit question
Old Apr 12, 2010 | 10:47 PM
hynes9000's Avatar
hynes9000
hey. ya . i have 2.5 in and i also got the 4 wheel shake .. its annoying but you just have o live with it .. Im a mechanic and every so often i stick her on the ramp and check out the front end and nothing seems to get any worst .... but other than that haha I love it and it sits level.
Old Apr 13, 2010 | 07:24 AM
jeffgank's Avatar
jeffgank
Originally Posted by hoss67
just measure from the top of ur fenders to the ground on the front and back, mine was almost 3inches different so i went with the 2.5"...
This is what i suggested to the guy. he didn't seem to get on board with that idea haha. maybe he just doesn't like em' for some reason. oh well, i'm going to measure and see what i come up with. The 4x4 shake does worry me... our winters are pretty brutal and i live in the woods. I can't get to a paved road from dec to feb without 4x4.
Old Apr 13, 2010 | 07:29 AM
LinerJoe's Avatar
LinerJoe
I don't think every person with a 2.5" lift gets it.... also, I don't know if the shake happens with 2" either? Truthfully, I notice it b/w 25-35 MPH.
joe
Old Apr 13, 2010 | 10:45 AM
dirtydog's Avatar
dirtydog
Moderate User
I would suggest picking up a set of Bilstein Lift struts for $230 at Moes' performance. They allow more articulation in the upper balljoint and do not max it out like the spacer kits do. The Bilstein lift strut kit is just that, new struts along with a level. they basically move the psring perch up to give you the added height.
Also, with the spacers, they not only max your upper balljoints out, they expand the shocks too much and cause "bottoming out". You will def be bottoming or maxing the shocks out in that case if your on side roads and have rough roads.
By the time you spend $80-100 on level spacers and then another $150 on shocks, you could have purchased the Bilstein kit for less and had a better ride that puts less strain on your front end components.
Old Apr 13, 2010 | 12:28 PM
jeffgank's Avatar
jeffgank
that sounds like a safer route...is there anyway of knowing how much it will lift the front? so that avoid my front end being higher than the back..
Thanks!
Old Apr 13, 2010 | 03:50 PM
hoss67's Avatar
hoss67
mine dont shake, if it shakes check out ur tie rod ends, garentee there goin bad
Old Apr 13, 2010 | 07:58 PM
03 off-road's Avatar
03 off-road
ok so sum it up fellas. i got 03 4x4 with 33's an they rub an i want to level it off. should i do the 2.5" or go with supension lift? i also use my 4x4 often
Old Apr 13, 2010 | 08:12 PM
hoss67's Avatar
hoss67
wat do they rub? inner fenders or UCA? if its ur uca u needs spacers or rims with good backspacing... if fenders level it, its cheaper and i have no problems with mine
Old Apr 13, 2010 | 08:48 PM
LinerJoe's Avatar
LinerJoe
You don't have struts on the front end. Can't you level it by cranking the torsion bars in the front? (As posted, depending on what it's rubbing, I don't know if it will help or not.) I don't think the 4x4 shake is common when cranking the torsion bars. Also, the stock 20's are 33" wheels, so that seems odd to me.
joe
Old Apr 13, 2010 | 08:56 PM
4.7Ram5.7Rango's Avatar
4.7Ram5.7Rango
If he has something like a 33x12.50 on a stock rim, it'd def rub on something. I have (basically) 33x11.50's and they rub on the uca on full lock. The level doesn't help anything with that, only spacers will, as mentioned
