3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Yeah I have been really really debating doing the Eyelids. I have aftermarket housings so I think it would look even cooler. I don't have the gay bubble thing over the bulbs. Question for you though, Did you sand the headlight or just use the adhesion Promoter and paint a couple layers then clear? Basically what were your steps on the headlights?
When I did my eyelids, I wetsanded the area I wanted to paint and applied one layer of adhesion promoter. Then 3 light coats of paint followed by 2 coats of clear. Some people also paint the inside of the housing lens but I can tell you that I had no light bleed with painting just the outside.
as for the bumper steps, they can be a bich to get off... they have little plastic things you have to squeeze together and push up with a needle nose plyers. the back wasnt too bad but the front was a pain because of my tow bar...
supposedly adhesion promoter takes the place of primer...and yes you want to clear anything you do on the outside of the vehicle UNLESS its a single stage quality paint
