Rear differential question.
Old Apr 16, 2010 | 10:38 PM
dodge32's Avatar
dodge32
Default Rear differential question.
Hello i just purchased a 2003 dodge ram qaud cab wih 128k mint condition exterior motor and all, but the only thing that concerns me and not sure if its normal is when your at a dead stop and u cut the wheel to make a turn he rear end feels like it locks a little or almost kinda skips on one wheel, hard to explain. It has the 3.92 gears
Old Apr 16, 2010 | 10:49 PM
gasguy's Avatar
gasguy
sounds like it is in 4wd, is it?
Old Apr 16, 2010 | 10:57 PM
HammerZ71's Avatar
HammerZ71
sounds like it's got a LSD and you need friction modifier in it to me...
Old Apr 16, 2010 | 11:04 PM
RedTruck-VA's Avatar
RedTruck-VA
Ditto, I would inspect the differential.
Old Apr 17, 2010 | 12:15 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Im with Hammer on this one also. Thats exactly what I was thinking.
Old Apr 17, 2010 | 11:05 AM
dodge32's Avatar
dodge32
thanks guys i checked its not in 4 wheel drive, the friction modifier sounds like a plan any you guys would recommend?
was also reading on the c clips in the rear end are they in the 3.92s?
Old Apr 17, 2010 | 11:28 AM
HammerZ71's Avatar
HammerZ71
I would pull the diff cover, do a visual inspection of the gears and make sure you have no Clips broken off in there, and refill with the proper lubricant and 4 oz. of friction modifier...
Old Apr 17, 2010 | 11:58 AM
FireFighter's Avatar
FireFighter
From: The old famed Gen3 Broken Valve Spring Thread - https://dodgeforum.com/forum/3rd-gen-ram-tech/237316
Yeah, do a thorough examination...read my last thread I started if you hadn't already
Old Apr 17, 2010 | 12:10 PM
dodge32's Avatar
dodge32
yes thanks i read the c clip thread you started its really crazy that dodge does this i will check it out sometime this weekend. i ran across the mobil full sythetic gear oil with the friction mod in it is that good enough?
Old Apr 17, 2010 | 12:22 PM
abarmby's Avatar
abarmby
I'm not a big fan of the friction modifier already in the oil.
I'd rather be able to add a little at a time, to have control over what's in my diff.
Start off with the 4oz previously mentioned and do several figure of 8 tight circuits both one way then the other, to mix it all up in the axle.
If you still feel a little shuddering/chatter, add an ounce at a time until all's well.
I don't know if you can have too much modifier in an oil, but at least using the method I described, you know for certain that you have just enough and your LSD will work at it's optimum.
Would too much modifier stop the LSD performing at it's fullest and cause slipping........????? I don't know? It's a clutch pack mechanism so too much would make it slip just as too little makes the clutch pack grab.
JMHO.
Al.
