Confused...
Old Apr 18, 2010 | 04:28 PM
crazyandy202's Avatar
crazyandy202
Default Confused...
So I took off my door panel and unhooked all of the connections just to take a look cause I thought something was loose inside of the door. So I hooked it all up and at first it didnt want to lock unless I locked it with the key remote then it fixed itself some how but now it does lock when I drive that first so many feet and it doesnt unlock the truck doors when I open up my door. Any ideas because I am just stumped.
Old Apr 18, 2010 | 04:59 PM
OklaHemi's Avatar
OklaHemi
um im pretty sure if you look in the owners manual they should have instructions to disable the auto lock feature
Old Apr 18, 2010 | 05:19 PM
rocket23's Avatar
rocket23
I dunno we as owners look atg the unlock feature in our key fob not by opening the doors. I'm not quite sure whats wqrong here. your thread is half right anyway it is a safety thing that the doors auto lock when driven over 15 mph. btw.
Old Apr 18, 2010 | 05:53 PM
crazyandy202
I got it to work i just unhook and reconnected the battery and sorry about that I didnt know it was at 15mph
Old Apr 18, 2010 | 09:36 PM
TRXHemi's Avatar
TRXHemi
I believe it is actually 20mph per the owner's manual....
Old Apr 18, 2010 | 11:23 PM
OklaHemi's Avatar
OklaHemi
page 18-19 of my manual says
Automatic Door Locks
if this feature is enabled, your door locks will lock automatically when the vehicles speed exceeds 15mph.
this feature is enabled when your vehicle is shipped from the assembly plant and can be diabled by using the following procedure
1. enter your vehicle and close all doors
2. fasten your seat belt( to eliminate other chimes that may confuse you)
3. place the key in the ignition
4. within 10 seconds cycle the key from the OFF position to the ON position 4 times; ending in the ON position(do not start vehicle)
5. within 30 seconds, press the the drivers door lock switch in the lock position
6. a single chime will be heard to indicate the feature has been disabled
7. to reactive this feature, repeat the above steps
8. no chime heard no good do it again
AUTO UNLOCK FEATURE
this feature unlocks all the doors of the vehicle when the drivers door is opened first. the following condidtions must be met.
-the drivers door must be opened first
-the automatic door lock feature must be enabled
-the doors of the vehicle must be locked automatically by the autolock feature
-the vehicle is in (P) park and the ignition switch is in the off position
-this feature will not operate if any of the above conditions are not met or the following has occured
-any manual operation of a door lock switch has occured
Old Apr 19, 2010 | 12:34 AM
rocket23's Avatar
rocket23
^^^ you forgot to poist if equipped. my 06 has not that feature in the truck.I wish it did. I asked about it at the dealer, i'm really starting to doubt there intelligence btw.
They said it wasn't happening with my truck, kinda arbitrarily I might add. Unless oklahemi, you know something I don't //
Old Apr 19, 2010 | 12:39 AM
OklaHemi's Avatar
OklaHemi
no i have an 04 baby **** computer not the full blown hitler canbus you guys have. i thought the procedure would be pretty general for all of the trucks that are equipped with it
Old Apr 19, 2010 | 01:01 AM
rocket23's Avatar
rocket23
my girls journey hs it .sweet all doors open at once I like that .
