545rfe shift kit for the Ram
Old Apr 18, 2010 | 10:33 PM
badblackram06's Avatar
badblackram06
Default 545rfe shift kit for the Ram
ok i have 2 questions.. I have been looking to improve the shifts on my 2006 Ram. They are just too smooth for me. I have even tried the Transmission line booster mod. It worked great for a few days (especially when the tranny was cold) and then my transmission started to feel like it was slipping and the shifts became less firm and took much longer. So i removed it as soon as i could. I bought a superchips flashpaq and it raised the shift pressure a good bit but there were no noticeable performance gains so i took it back. i couldnt see spending 400 bucks on a programmer that just changed shift points and pressure. But I have looked around on the net and found a few kits for the 45rfe/545rfe but they all say 99-05 models. I was hoping to find one but looks like i'm out of luck again. Do they have a kit specifically for the 2006+ or will the 99-05 kit on the 06 models?
Ok second question.. Does B&M make the Trick Shift fluid in ATF +4? I've used it before in various vehicles and i was surprised that it helped alot with shift pressure. Maybe some one will give me some good news on any of this lol.. Thanks
Old Apr 18, 2010 | 11:07 PM
OlDirtyJohn's Avatar
OlDirtyJohn
dont use anything other than good old atf+4 in these trannys. not even additives. they are super fussy about that. transgo HD-2 will work on any year 545RFE. why not save up for a sharadon valve body? its better than a shift kit.
and you didnt feel any performance gains with a superchips? are you sure you were using it correctly?
Old Apr 18, 2010 | 11:43 PM
badblackram06
Ah thanks, i was just curious about the fluid. and is stage 2 or stage 3 better for just normal street use? Maybe occasional drag runs.
Maybe this would explain the no performance gains, i have the 4.7L. I would have figured it would have helped a little... When i had it programmed I drove around for about a week and a half to let the pcm relearn the performance tune but nothing ever changed. I didn't see any changes in the times using the data logging. I even filled the tank with 93 before i programmed it. The only gains i saw were in mpgs on both the performance tune and the Mileage XS tune. But i was satisfied with the shifts just not enough to keep it.
Old Apr 19, 2010 | 12:56 AM
OlDirtyJohn
stage 2 is your best bet for a daily driver. stage 3 is more for track. sucks about the superchips though. they usually work out awesome for just about everyone.
Old Apr 19, 2010 | 10:13 PM
badblackram06
ah ok, and yeah it does. i've used a superchips since i was 17 and 4 trucks later this is the most disappointing.
