late model rear differential ques.
Old Apr 19, 2010 | 02:38 PM
HammerZ71's Avatar
HammerZ71
It was widely accepted that the change to a stronger clip with the '06s fixed the issue. For a time it appeared so, but IMO it was basically because the '06s had a bit heftier clip AND did not have the mileage on them that the older model years had when their clips would fail.
Now that the 06+ trucks have been out a while, it does appear that the instances of clip failure are down a good percentage from the 05 and before models that were equipped with a factory LSD. However, the issue DOES still exist. So for the newer truck owners, a good, visual inspection is still STRONGLY RECOMMENDED at fluid change time.
Also, the larger clips DOES NOT change the fact that the stock LSD is still a rather poor functioning POS and still needs some light braking or a slight application of e-brake just to function at all.
If it's within budget and you do the type of driving where you rely on a LSD, it's still highly advisable to get a DTT or Auburn unit...
Old Apr 19, 2010 | 03:06 PM
rocket23's Avatar
rocket23
^^^ 1000% agree, However A regular smoe like me going off road once a year and 4 wheeling basically in the snow, you would think I/we 06's and beyond should be good to go at least for the 75'ooo miles I would imagine. But anything can happen on any given day with these set ups. yes??
Old Apr 19, 2010 | 05:49 PM
lxman1's Avatar
lxman1
Site Moderator
My LS works great. One tire on ice, one on pavement and it doesn't spin at all (moderate throttle). 32K miles and it hasn't broke yet
