Programming features (door locks, power, etc).
Old Apr 19, 2010 | 08:35 PM
Rojhan's Avatar
Rojhan
Default Programming features (door locks, power, etc).
When I got my truck from the dealer, there was a cheat-sheet for how to program some of the electrical features like unlock driver/unlock all, 15mph lock, accessory power always on vs on with ignition, etc.
I've lost that cheat sheet and have spent about 20 minutes searching the owner manual, forum and Google for the programming method (ignition on/off, brake pedal, door lock button, etc).
Anybody have programming information specifically for making the accessory power outlets only live when the ignition is on? A source for all of the programming cheats including oil-change reset, etc?
Maybe a sticky?
Thanks,
Old Apr 20, 2010 | 06:12 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Sorry, IDK of any but are you also on the Cummins board?
Old Apr 20, 2010 | 09:00 AM
Rojhan's Avatar
Rojhan
Why? I don't have a diesel.
I did post a long time ago in the Cummins board on DF when I was thinking about a 3500.
Old Apr 20, 2010 | 09:06 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
So you got a 2500 gasser? Ouch. Why not a diesel?
CTD is where I want to go.
Old Apr 20, 2010 | 09:18 AM
Rojhan's Avatar
Rojhan
The delta in purchase and operating costs were larger than the benefit of periodic/intermittent need for the higher payload on a vehicle that sees about 7,000 miles/year.
Old Apr 20, 2010 | 09:26 AM
caliboy@heart's Avatar
caliboy@heart
I dont think that this was an option on my 04...
Old Apr 20, 2010 | 09:29 AM
dirtydog's Avatar
dirtydog
Moderate User
I dont get why everyone is soooooo into diesels???
They are a PIA to get worked on as nooooobody wants to touch them. Atleast not around here anyways. Not that i couldn't do anything myself, just most people aren't that knowledgeable. Plus, they are rather pricey for parts as they are considered "commercial vehicles".
They are loud/noisey, they smell, and not every gas station around here even carries diesel, so you need to plan ahead of time for fuel.
The ONLY benefit I see in having a diesel for me is longevity. Plugging in a personal vehicle every night in the winter is not something I would want to do either.
Ohh, then there's the price tag that some can't afford.....ouch!....lol
Old Apr 20, 2010 | 10:17 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
THREAD JACK
I want one for a few reasons. One, they certainly get better MPG than mine does. Then there are the bio-diesel setups that are available. Chit, us gassers will NEVER EVER see ANYTHING close to that. There is more hidden power and potential than a gasser. Like you, i work on my own rides and ALWAYS have. if I can put my hands on it, I can make it work. I truck now is noisey. I know what you mean but it cant be any more loud than my exhaust I have now. ;-) Smelly is what mine already is with no cats. ;-) Lots of places down here have diesel but I understand what you mean about planned ahead for fuel
That longevity on a diesel is something else I envy. 200K on ours and were are looking for a replacement or rebuild. 200K on a diesel is just getting started.
Our temps here arent like in NY where you need a block heater. Here we just need coolers and good ACs. LOL
Old Apr 20, 2010 | 09:14 PM
Rojhan's Avatar
Rojhan
Found at: http://www.ramforumz.com/showthread.php?t=48478
To unlock the doors:
Press and release the UNLOCK button on the key fob
once to unlock only the driver’s door or twice to unlock
all the doors. When the UNLOCK button is pressed, the
illuminated entry will initiate, the parking lights will
flash on twice and if installed, the cargo lamp will turn on
for 30 seconds.
The system can be programmed to unlock all the doors or
drivers door only upon the first UNLOCK button press
by using the following procedure:
1. Perform this operation while standing outside the
vehicle.
2. Press and hold the LOCK button on your key fob.
3. Continue to hold the LOCK button at least 4 seconds,
but no longer than 10 seconds, then press and hold the
UNLOCK button while still holding the LOCK button.
4. Release both buttons at the same time.
Horn Chirp
The horn chirp feature will be shipped from the assembly
plants activated. If desired this feature can be disabled by
vehicle.
2. Press and hold the LOCK button on a programmed
(i.e. functional) key fob.
3. Continue to hold the LOCK button, wait at least 4
seconds, but no longer than 10 seconds, then press and hold
the PANIC button. Release both buttons at the same time.
4. To reactivate this feature, repeat the above steps.
Vehicles will be shipped from the assembly plants with
the park lamp flash feature activated. If desired, this
feature can be disabled by using the following procedure:
vehicle.
2. Press and hold the UNLOCK button on a programmed
3. Continue to hold the UNLOCK button, wait at least 4
hold the LOCK button. Release both buttons at the same
time.
Automatic Door Lock Programming
This feature is enabled when your vehicle is shipped
from the assembly plant and can be disabled by using the
1. Enter your vehicle and close all doors.
2. Fasten your seat belt (Fastening the seat belt will
cancel any chiming that may confuse you during this
programming procedure).
3. Place the key into the ignition.
4. Within 15 seconds cycle the key from the LOCK
position to the ON/RUN position a minimum of four
times; ending in the LOCK position (do not start the
engine).
5. Within 30 seconds, press the driver’s door lock switch
in the LOCK direction.
6. Asingle chime will be heard to indicate the feature has
been disabled.
7. To reactivate this feature, repeat the above steps.
8. If a chime is not heard, program mode was canceled
before the feature could be disabled. If necessary, repeat
the above procedure.
Auto Unlock On Exit — If Equipped
This feature unlocks all of the doors of the vehicle when
any door is opened. This will occur only after the vehicle
has been shifted into the Park position after the vehicle
has been driven (shifted out of Park and all doors closed).
This feature will not operate if there is any manual
operation of the power door locks (Lock or Unlock).
Auto Unlock On Exit Programming — If Equipped
Customer Programming sequence to enable or disable
the Auto Unlock Feature:
2. Fasten your seat belt (fastening the seat belt will cancel
any chimes that may be confusing during this programming
procedure).
3. Insert the key into the ignition.
4. Within 15 seconds, cycle the key from the LOCK
times ending in the LOCK position (do not start the
engine).
in the UNLOCK direction.
6. A single chime will sound to indicate the feature has
been changed.
7. Repeat the above steps to alternate the availability of
this feature.
before the feature could be changed. If necessary repeat
Enhanced Seat Belt Reminder System (BeltAlert)
If the driver’s seat belt has not been buckled within 60
seconds of starting the vehicle and if the vehicle speed is
greater than 5 mph (8 km/h), the Enhanced Warning
System (BeltAlert) will alert the driver to buckle their seat
belt. The driver should also instruct all other occupants to
buckle their seat belts. Once the warning is triggered, the
Enhanced Warning System (BeltAlert) will continue to
chime and flash the Seat Belt Warning Light for 96
seconds or until the driver’s seat belt is buckled. The
Enhanced Warning System (BeltAlert) will be reactivated
if the ignition is cycled, driver’s seat belt is unbuckled for
more than 10 seconds and the vehicle speed is greater
than 5 mph (8 km/h).
The Enhanced Warning System (BeltAlert) can be enabled
or disabled by your authorized dealer or by
following these steps:
NOTE: The following steps must occur within the first
60 seconds of the ignition switch being turned to the ON
or START position. DaimlerChrysler does not recommend
deactivating the Enhanced Warning System
(BeltAlert).
1. With all doors closed and the ignition switch in any
position except On or Start, buckle the driver’s seat belt.
2. Turn the ignition switch to the ON position and wait
for the Seat Belt Warning Light to turn off.
3. Within 60 seconds of turning the ignition switch to the
ON position, unbuckle and then re-buckle the driver’s
seat belt at least three times within 10 seconds, ending
with the seat belt buckled.
NOTE: Watch for the Seat Belt Warning Light to turn on
while unbuckling and off while re-buckling the seat belt.
It may be necessary to retract the seat belt.
4. Turn the ignition switch to the LOCK position. A
single chime will sound to signify that you have successfully
completed the programming.
The Enhanced Warning System (BeltAlert) can be reactivated
by repeating this procedure.
NOTE: Although the Enhanced Warning System
(BeltAlert) has been deactivated, the Seat Belt Warning
Light will continue to illuminate while the driver’s seat
belt remains unbuckled.
Nothing on the accesory power settings, and I haven't tried it, but here it is.
