More differential questions
Old Apr 22, 2010 | 05:11 PM
bball14's Avatar
bball14
Default More differential questions
I have been sorting through old threads for about an hour and have not answered all my questions.
1. Do the front and rear diffs use a different weight of fluid? ( I don't have an owner's manual to refer to)
2. I keep seeing differing opinions of using rtv OR a gasket or BOTH? Whats the concensus on the guys?
Thanks for your help.
Old Apr 22, 2010 | 05:20 PM
rocket23's Avatar
rocket23
Yes per owners manual 75w-90 in the front diff, and 75w-140 in the rear diff. I used valvoline full syn on mine (it already has the additive in it) When you pull yours apart you will see an orange residue that is rvt form a gasket scrapeit off good and replace with eithyer red blue or black really doesn't matter btw. enjoy and post pix when done
Old Apr 22, 2010 | 05:26 PM
ramhunter9's Avatar
ramhunter9
depends on the truck 1500 or 2500
i called 2 dodge dealers to find out and both came back the same .....
1500 ram front 75w-90
rear 75w-90 ..unless you tow allot use 75w-140
2500 ram front and back 75w-140
the 1500 youneed RVT
the 2500 you re use the gasket .
Old Apr 22, 2010 | 05:51 PM
rocket23's Avatar
rocket23
asuming the 1500 , use the 90 in front and 140 in the a$$ these diff's are tempermental as it is. imo.
Old Apr 22, 2010 | 05:54 PM
ramhunter9's Avatar
ramhunter9
for a 1500 yes i agree
for mine i tow ect , and wit no c-clips to worry about im good .
Old Apr 22, 2010 | 06:20 PM
rocket23's Avatar
rocket23
And totm winner too boot, rh.
Old Apr 22, 2010 | 06:24 PM
ramhunter9's Avatar
ramhunter9
2x ...dont forget that lol
Old Apr 22, 2010 | 06:34 PM
rocket23's Avatar
rocket23
Now go post on my jacked up thread!@! lol
Old Apr 22, 2010 | 07:00 PM
HammerZ71's Avatar
HammerZ71
They sell gaskets for the 1500 diffs, but if you apply the RTV correctly it is actually more reliable than a gasket.
Your choice though.
As far as the fluid goes, if you do not tow or haul a lot, then you can just buy 75/90 for both. I don't tow often but on occasion have pulled a 7500# tractor on a big dual axle trailer. Couple that with the fact that I have to run a conventional oil in the rear according to the gospel of St. Auburn, I run a 85/140 Lucas Heavy Duty conventional oil. I run a 75/90 synthetic in the front...
Old Apr 22, 2010 | 07:04 PM
rocket23's Avatar
rocket23
Your choice though...
Never knew that .rtv is what i di but I could see myself picking up a gasket just in case. Napa, autozone one of those places i imagine.?
