error code 0405
Old Apr 24, 2010 | 04:14 PM
catawissarocket's Avatar
catawissarocket
Default error code 0405
Could someone give me the error code 0405 for 05 ram 1500 with 5.7 hemi?
Old Apr 24, 2010 | 04:28 PM
AWE Daniel's Avatar
AWE Daniel
Up in the FAQ there is a list of all codes, next time check there first.
https://dodgeforum.com/forum/3rd-gen...m-alldata.html
P0405 is a EGR Position Sensor Low Voltage indicator, it can be thrown by the EGR not being in the right place right time etc (edit: could also be a bad sensor). First things first check your EGR connector harness and make sure its not dirty. Then you should probably look at all the wires coming off of it to make sure they look ok. Could be a bad sensor and needs to be replaced. As for where the sensor is, you got me.
Old Apr 24, 2010 | 04:31 PM
JoeHemi's Avatar
JoeHemi
yeah, and if you havent changed your EGR out yet, it's probably time to do so. They clog up pretty quick on our hemis.
Old Apr 24, 2010 | 04:50 PM
AWE Daniel's Avatar
AWE Daniel
It couldnt hurt to change it, but the CEL was tripped by the voltage being lower than .2V, which says that there is something else going on there, probably and old shorted out sensor.
Old Apr 24, 2010 | 05:03 PM
JoeHemi's Avatar
JoeHemi
Im pretty sure the sensor is built into the EGR. First thing would be to clean the plug like Daniel mentioned but chances are its shorting out in the valve housing and relaying the low voltage back to the PCM.
Old Apr 24, 2010 | 07:59 PM
catawissarocket
Thanks guys. i'm going to pick one up tomorrow. truck has acting up lately,idle up and down feels real slugish and and just stalls out sometimes randomly. was getting error codes 0404 which is 02 upstream sensor,0420 and 0405. changed the 02 left and right awhile ago but still throws that 0404 code. some say 40 key starts and it will clear but i've done way more than that. gonna change the egr tomorrow, already cleaned it up but to no avail didn't help..
Old Apr 24, 2010 | 09:39 PM
AWE Daniel's Avatar
AWE Daniel
So that's where the sensor is huh? I know on some vehicles it is a separate 60-70$ part. If its been idling like that then def try to swap it out. While your at it you might wanna check and clean your throttle body too. If you wanna try to get rid of the code and the CEL, either disconnect your batt for a few minutes or do the pcm reset thats in the FAQ.
Old Apr 24, 2010 | 10:38 PM
catawissarocket
Thanks,i did clean the TB. I'll see if i can find the pcm reset what ever that is.
Old Apr 24, 2010 | 10:41 PM
catawissarocket
Could someone find me a link for the pcm reset? i couldn't find info about it. thanks
Old Apr 25, 2010 | 12:15 AM
JoeHemi's Avatar
JoeHemi
Here, this link will provide you with the info you need
https://dodgeforum.com/forum/3rd-gen...reset-pcm.html
