HELP....Please, Turn Signal Chaos!!
First let me say hi, name is Rich, I go by Putt here on the net. I'm a proud owner of a new (to me) '04 Dodge Ram 1500 4x4.......
The truck is in excellent shape. I had to change the front brake's yesterday and fix a turn signal lamp that was out (yea right). the brakes went well, my problem started when i went to fix the signals.
When I hit the right turn signals, the flashers going a million times a second, lamp out indicator light on the dash is on, left signals work fine. I changed EVERY lamp on the truck, swapped the circuit boards in the back and still, no rear right turn signals. I went to my friendly local autozone to pick up a new flasher and they tell me rthere is no flasher for this truck............
Help guys..... What else should I be looking at....It's driving me nutz....
Rich
Rich
Normally when the turn signal is blinking really quickly it meant that you have a brake light out, not a turn signal out. I just replaced my driverside brake light today, same isue with the turn signall flashing quicker than usual
geez!! just what we need around here!! another silver regular cab running on flower petals!!!! lmao just kidding bro! sharp looking truck! cant help you with the turn signal but welcome to DF anyway!
"dual filament bulbs are in the right way"
Are you kidding me?
They really only go in one way..........heck, and I'm a electricain by trade LOL
Are you kidding me?
Trending Topics
When I hit the right turn signals, the flashers going a million times a second, lamp out indicator light on the dash is on, left signals work fine. I changed EVERY lamp on the truck, swapped the circuit boards in the back and still, no rear left turn signals. I went to my friendly local autozone to pick up a new flasher and they tell me rthere is no flasher for this truck............
Rich
That was pretty observant. But my bad, typo....No matter which board is plugged into the right side, it doesn't work and vise versa, no matter which board is plugged into the left side, the left side works................
