trouble code p0113
Old Oct 6, 2012 | 10:12 PM
willdikem66's Avatar
willdikem66
Rockauto has the sensor cheaper, thats about the only way to get rid of the problem is to replace the sensor
Old Oct 7, 2012 | 06:37 PM
p38251's Avatar
p38251
Agree take the pwr wire off. Code gone you know pwr wire is bad. If code is still there replace the sensor.
Old Oct 8, 2012 | 12:37 PM
DodgeCares's Avatar
DodgeCares
Originally Posted by LUPE999
I got a p0113 code on my 2008 dodge mega cab....anyone know what that is and how t fix?
Lupe,
Below is the description of code P0113.
P0113-INTAKE AIR TEMPERATURE SENSOR CIRCUIT HIGH
  1. When Monitored: With the ignition on. Battery voltage greater than 10.4 volts.
  2. Set Condition: The PCM detects that the Intake Air Temperature Sensor input voltage is above the maximum acceptable value
Possible Causes
(K21) IAT SIGNAL CIRCUIT SHORTED TO VOLTAGE
(K21) IAT SIGNAL CIRCUIT OPEN
(K900) SENSOR GROUND CIRCUIT OPEN
IAT SENSOR
POWERTRAIN CONTROL MODULE (PCM)
Old Oct 8, 2012 | 02:25 PM
willdikem66
Like we said just replace the 30 dollar sensor, its more than likey your problem
