help engine blew up!
Old May 2, 2010 | 08:50 PM
moparmike01's Avatar
moparmike01
A long block is a complete engine, except it requires the external parts like harmonic balancer, valve covers, exhaust and intake manifolds, flywheel, timing cover and oil pan. The external parts are additional purchases, and will need installation.
A short block consists of only the engine block, and needs internal parts such as oil pump, cylinder heads, lifters and gaskets. These parts are also additional purchases and need installation. A short block may or may not come
with timing parts and camshafts. If you aren't a professional mechanic you should consider hiring one to install these parts.
Difference in Expense
The internal parts needed for a short block are more expensive and take more time to install than the external parts needed for a long block. Therefore, by spending extra money for parts and labor you will probably invest as much money, if not more, in a short block, than if you had purchased the more complete long block to begin with.
Old May 2, 2010 | 08:51 PM
rocket23's Avatar
rocket23
somebody miss athread?/^^^
Old May 3, 2010 | 01:49 AM
lastrights's Avatar
lastrights
maybe your plenum just crapped the bed ?? i dunno
Old May 3, 2010 | 01:58 AM
rocket23's Avatar
rocket23
Plenum?? no no go back a few posts that guy is way off topic imo.
Old May 3, 2010 | 08:05 PM
jose13b's Avatar
jose13b
ok push rods are bent heads are cracked I looked at it myself and I found a dodge ram in the junk yard with only 54000 miles so I bought the motor for 1500 and had my motor pulled out today
Old May 3, 2010 | 08:17 PM
jose13b's Avatar
jose13b
pics of rods and spring
Old May 3, 2010 | 08:35 PM
jose13b's Avatar
jose13b
motor is out
[IMG]https://dodgeforum.com/forum/Name:  IMG950031.jpg
Size:  5.5 KB[QUOTEName:  IMG950031.jpg
Size:  5.5 KB][/QUOTE]
Old May 3, 2010 | 09:39 PM
lastrights's Avatar
lastrights
geeze man!!! save that throttle body and mod it from the old motor , and you could take the plenum too and mod that cut the runners on it
Old May 7, 2010 | 08:35 AM
jose13b's Avatar
jose13b
I have no ideal what your talking about
