ABS and Brake Light On
I have a 03 Ram 1500 5.7L and the ABS and brake light stay on.There is an audible warning sound and speedometer work fine.The ABS kicks in sometimes while braking on a dry road. I have read previous threads about the diff Speed sensor,could this be the problem? Thanks...
is there manny type diff-sensor that is used?
mine look like this:
my car is a 2002 1500 ram 5.9 gas
All the sensors I can find is a totally different sensor! all plastic and a bracket with a hole to fasten the sensor.
do anyone know the part # on the one I have (pic)?
I am having a very similar problem, my ABS amber warning light is on. No audiable warning. My problem was caused by installing a DSP tune and doesn't clear. DSP is working on a fix for me. Yours sounds like a RWAL/VSS problem. I would check the connection for moisture/damage. Good luck...
