heeeelp
Old May 4, 2010 | 02:32 AM
2002ram360's Avatar
2002ram360
Question heeeelp
i bought a 2002 dodge ram 1500 5.9 about a month ago ran like a beast. then radiator busted so i replaced it, in doing so also replaced the thermostat and duralast battery. i started it and a **** load of white smoke started to blow from the exhaust. could somthing maybe loose? i need help because now i have no mode of transportation. blown head gasket? thermostat leak?
thank you
Old May 4, 2010 | 02:49 AM
bigdaddyII's Avatar
bigdaddyII
Head gasket would be my first guess.
Old May 4, 2010 | 02:54 AM
abarmby's Avatar
abarmby
Lots of white smoke out the exhaust = water in the combution chamber.
Cracked heads/head gaskets unfortunately?
Is your coolant reservoir level dropping? Check for a white emulsion in your engine oil as well.
If you can't see any of that, there's a test kit you can buy to test your coolant for emissions in it. If there are, it's one of the two things mentioned.
Al.
Old May 4, 2010 | 07:34 AM
SMKNRAM's Avatar
SMKNRAM
did it get hot before you started replacing parts?
Old May 4, 2010 | 07:39 AM
Duroc's Avatar
Duroc
Yep, if you are lucky you only blew a head gasket. Almost certainly the heads will need to be pulled/pressure tested. Hopefully its not a cracked head.
