Manual Torque Converter Lockup
Old 05-10-2010, 11:28 AM
363coupe's Avatar
363coupe
363coupe is offline
Default Manual Torque Converter Lockup
I've got a 2002 Dodge Ram 1500 5.9L 2wd that I use to pull my 26ft camper with. I did some searching and I came up empty handed. Is there anyway to put a switch on your converter to where you can manually unlock and lock it? I know it can be done on some Chevy transmissions but I didn't know if it was possible with my truck.
Thanks in advance..
Old 05-10-2010, 12:08 PM
tlawre87's Avatar
tlawre87
tlawre87 is offline
If i remember right the 46re is an automatic lockup, it goes into lockup once you go into 4th gear with no heavy load. I don't think there is a way. The 42re is that way at least.
Old 05-10-2010, 12:26 PM
363coupe's Avatar
363coupe
363coupe is offline
Thats what I'm wanting to bypass is the auto lockup.
When I'm in OD going around 60 mph my RPM's are at 1,400-1,500 with the converter locked up. I'm wanting to make it to where the tranny doesn't tell the converter to lockup so it'll get more RPM's in OD to keep it from downshifting as much.
Old 05-10-2010, 01:03 PM
AF_HEMI's Avatar
AF_HEMI
AF_HEMI is offline
an unlocked converter on the highway is asking for a tremendous heat buildup. ESPECIALLY if you're pulling a load. Just let the tranny do its thing. These trannys might be inefficient, but they know more about what they're doing than you do (no offense intended).
Old 05-10-2010, 01:41 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
I used to have a B&M Lockup Kit on my 200r4 trans in my Olds 442. I know this is a long ways away from a 545rfe but maybe you can check with companies like them for some input
Old 05-10-2010, 02:09 PM
363coupe's Avatar
363coupe
363coupe is offline
Thats my problem, I'm only finding them for the 200r4 and the 700r4. It may not be possible.
Old 05-10-2010, 02:19 PM
nim81's Avatar
nim81
nim81 is offline
you can tap the brake to lock up the tq conv. maybe somehow run a switch to the brake switch that locks up the converter...?
Old 05-10-2010, 02:32 PM
363coupe's Avatar
363coupe
363coupe is offline
I want to be able to unlock it.
Old 05-10-2010, 04:55 PM
nim81's Avatar
nim81
nim81 is offline
you might be looking at a new tq converter with a different stall...
Old 05-10-2010, 05:04 PM
RedTruck-VA's Avatar
RedTruck-VA
RedTruck-VA is offline
Man, I can't but think that is not a good idea. If the load is light let it lock up as it will reduce heat. But I understand what you are saying and I believe what you really need is gears. That will make it drive the way you want it to and not be shifting all the time.
Quick Reply: Manual Torque Converter Lockup
