Help identify plug under driver side dash please
Old May 12, 2010 | 07:02 AM
MikeHTally's Avatar
MikeHTally
That's exactly what powers my GPS. Also the driving light relay, and the radar detector. All use the switched outlet I referred to. My e-fan relay is driven off a different switched power source.
Old May 12, 2010 | 07:08 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
VSS is needed to tap for Vehicle Speed for GPS. Thats a standard wire to tap for GPS accuracy actually. Most GPS units need that wire.
Old May 12, 2010 | 07:09 AM
AF_HEMI's Avatar
AF_HEMI
mine doesnt use it. then again, i have a handheld unit so its a whole different animal
Old May 12, 2010 | 07:17 AM
MikeHTally's Avatar
MikeHTally
Hmmm. My Garmin checks in with the satellites every six seconds (or six times a minute, I forget which). That's how it determines vehicle speed (and updates the location).
Old May 13, 2010 | 05:26 PM
rokclimbertx's Avatar
rokclimbertx
not to hijack, but i've been trying to figure out for the past few days what factory switch would go where that dash plug/cover is... and if i can use it for a more stock look for fogs & hellas i'm adding...
definitely will use the switch for ign.power when i wire up some hellas & fogs to their relays & switches...
Old May 14, 2010 | 11:09 AM
Mega-Hemi's Avatar
Mega-Hemi
Did you not read the first 5 posts?
Old May 14, 2010 | 11:16 AM
crazyandy202's Avatar
crazyandy202
haha I just tapped off of my power outlet
Old May 14, 2010 | 02:20 PM
rokclimbertx
as a matter of fact i did... they explain what the electrical (light blue) plug is for...
i however am curious as to what switch, toggle, dial or button would be there in place of the cover that's in the hole. i can't imagine there being a "power pedal" sticking out of that area.
if there is a stock switch, toggle, dial or button that fits that hole, i wonder if i could use it for the auxiliary lights i'm adding.
thanks for letting me clear that up...
Old May 14, 2010 | 05:26 PM
Mega-Hemi's Avatar
Mega-Hemi
It's the switch for the power pedals, as mentioned earlier. It's a momentary switch just like what is used for your power windows. You push the switch and your pedals move forward or back. I will try to get a pic a little later.
Old May 14, 2010 | 05:43 PM
rokclimbertx
i see... now it's making more sense... doesn't sound like a good switch for aux. lights if it's similar to the power window switch...
thanks!!
