New to the board, need some help 2008 1500 Ram
Old May 15, 2010 | 08:38 PM
Deerhunter's Avatar
Deerhunter
Default New to the board, need some help 2008 1500 Ram
I have a 2008 quad cab Ram 2wd with the 4.7 in it.
It now has about 35,000 miles on it, I have put 30,000 on it running my rural mail route. My roads are pretty rough on a truck.
This truck is a salvage title truck and has been a good truck so far.
Well Friday it died on me a couple times and then got hard to start, you would have to crank and crank to get it running.
I checked the codes and come up with 300, 335, and 339.
I was told the 335 was the crank trigger sensor, so I found one today at a dealership and bought it brought it home and installed it and, you guessed it, the new sensor didn't fix a thing.
So we wanted to know if it was a fuel issue or a firing issue so we sprayed carb cleaner directly down the throttle body and it wouldn't run on that so we think it's an ignition issue.
Any help or suggestions would be appreciated.
Thanks,
Jeff
Old May 16, 2010 | 12:57 AM
dazed01's Avatar
dazed01
You have low battery voltage, very corroded battery terminals or cables or bad wiring or connector at the crank sensor?
Old May 16, 2010 | 10:56 AM
Deerhunter's Avatar
Deerhunter
Thanks for the reply, I will check the battery, but leaning toward the wiring on the crank trigger.
Any ideas at this point is appreciated.
Old May 16, 2010 | 05:55 PM
Deerhunter's Avatar
Deerhunter
Battery turns engine over really well, but I did clean the terminals, but no help.
I also checked a couple plug ends and wires with no luck.
Checked the exhaust, thinking the cats may have been stopped up, but they weren't the best I could tell.
Anyone have any other ideas.
Old May 16, 2010 | 06:43 PM
ramhunter9's Avatar
ramhunter9
you need spark and fuel to turn a engine , those 2 things should be checked .
Old May 16, 2010 | 09:19 PM
Deerhunter's Avatar
Deerhunter
ramhunter, it will run but it's hard to start, and it doesn't have any power.
BTW cool truck you have.
And a big thumbs up on Illinois for the deer hunting. We have been to Pike county and hunted some.
Old May 16, 2010 | 10:53 PM
Deerhunter's Avatar
Deerhunter
Thanks for any other ideas.
I will call the dealership tomorrow and get on the list. Oh boy.
Old May 16, 2010 | 11:12 PM
Pyro's Avatar
Pyro
I Beat Tetris
P0300 Multiple Cylinder Misfire
P0335 Crank Pos Sens Circ
P0339 Crank Pos Sens Circ Interm
Your crack position sensor is root of the problem, if you replaced the sensor and it's still doing it, check that you installed it correctly, check the wires and lines for corrosion, and reset the PCM.
Old May 17, 2010 | 04:51 PM
Deerhunter's Avatar
Deerhunter
I will have to run down the wires to the crank sensor. I replaced the sensor and it didn't help.
I called the dealership today and it will be the first of next week before they can get it in.
I just wish it would go into overdrive.
Got to work, so the truck must go regardless.
Old May 19, 2010 | 09:11 PM
Deerhunter's Avatar
Deerhunter
Well I threw a cam sensor at it today since it was cheap and that didn't fix it either.
