add a leaf?
#21
#22
#23
#24
#27
on
1 Post
So your 6" lift came with an add-a-lift and blocks? and you swapped the blocks for shackles? Any additional lift from using shackles instead of your blocks? Can you post a link to the shackles you got? Im very interested in copying you.
"I got some shackles in the back.. ya know if you're into that kinda thing heh heh. Nah im just kiddin. But seriously, I got em" W.h.i.t......e
#28
You should see my man *****!
My lift came with just one giant block for the rear. I don't mind a small block, but a 3.5" block was just too much for me. It looked like doodoo. I pulled the block out and replaced it with a 2.5" AAL and a 3" shackle.
I got the shackles off of ebay. Search for 2nd gen drop shackles. Sounds weird but it has to do with the different way the shackles mount between the two gens.
The thing to remember with shackles is that you only get half the lift due to geometry. A 3" shackle (meaning 3" longer than stock) only lifts you 1.5". The reason is that you are only lifting one side of the spring. The front shackle mount stays in the same place as stock. Think of a board laying on the ground. You lift one end of it 3" and then go measure the height in the middle of the board. The middle is only 1.5" off the ground, because the far end is still on the ground. Our axles mount in the middle of the board (spring).
#29
on
1 Post
You've inspired me. As soon as I get off this government computer, I'll check out ebay. I want the rear another inch higher because i feel like its not quite level. I have a 1" block now that came with the Fabtech lift, so 3" shackles would be perfect. Thanks for info. You can keep your man *****
#30
My Arnott airbags actually lifted the back 1/2" when I put the minimum of 5lbs air in them. Each few lbs of air in thereafter, the bags slowly raise the back up even more. If I have 20#'s in them with the bed empty, my *** end is roughly 1" higher than stock. If I put in maximum 100psi in them, my back is 1.5" higher than stock, so the air raises the back initially, but after 20-30lbs, it doesn't raise much higher after that.
I would say get airbags personally because I ride around with 20lbs al the time and the ride is great. Not much stiffer than stocdk at all.
Install took me less than 1hr and there was no drilling or welding involved. Super easy install in my books. Did them on my back in my driveway. Paid $225 shipped off egay.
