swapping to srt 60
hey guys have located a regular cab srt rear end want to put it in my 03 quad cab 4x4 whats it take can i use the srt brakes i have 17" wheels i shure i have to flip the pads what about the speed sensor drive line alll help would be great
thank you guy
thank you guy
PLEASE use punctuation!! It make out deciphering of your post SO MUCH easier!
What gears do do you have now in the front diff and what gears are in the SRT rear diff because they BETTER match up or no 4wd for you. And being you are in WA, I am assuming you need your 4wd.
I'm just kiddin' ya bro. I know you meant it makes deciphering of your post so much easier. Yes OP, like Weed said the gears have to match in the front and rear ends.
sorry guys...the srt has 456 and so does my truck. just wondering about the srt brakes with 17" wheels? As for the speed sensor does it just use the same plug?
The 9.25 has just being hell for problems..so i need as much help as possible
thank you guys
thank you guys
The plugs should be the same. The brake will make no difference. A lot of guys like the bigger brakes for more surface area to help stop better/faster. As long as your from diff has 456 you will be fine.
Trending Topics
If you do it post up a lot of pics, I wanna see how it turns out. The rear SRT brakes are damn near the same as our regular front brakes, at least as far as rotor's and calipers go. The fronts you will need at least a 20" rim I believe if you plan on taking it that far.
http://shop.jtsvp.com/product.sc?pro...categoryId=176
