Help Me Build My Hood!
Old May 19, 2010 | 10:14 PM
Brado34's Avatar
Brado34
Default Help Me Build My Hood!
Whats up guys,
So I have started to create my version of a Venom Hood.
i want to make it functional.. just wondering what size i should cut my hole.. and how i could possibly make a ram air intake.
Old May 19, 2010 | 10:23 PM
oefootball_70's Avatar
oefootball_70
Cut it to the size of the opening of the scoop that you make. Make the scoop, then get it mounted to the hood. Then worry about cutting it, then fiber glass and paint.
Thats what I would do.
Old May 19, 2010 | 10:31 PM
Brado34's Avatar
Brado34
for building a ram air intake could i not just use pvc piping attatched to a homemade cai?
make it like this one below but just homemade.
http://www.truckinweb.com/tech/engin.../photo_01.html
drill a hole into my air box and attatch some pvc piping to a funnel?
im not sure as to where i would have to cut the hood so that i dont get any unwanted stuff in my intake.. such as water and stuff..
Old May 19, 2010 | 10:33 PM
oefootball_70
I would build a pvc set up. With a rectangle filter right behind the hole you cut. With a grill on the hole (guttah grill maybe)
Old May 19, 2010 | 10:34 PM
truckin151's Avatar
truckin151
Well you are going to need to do some fab work under the hood, making the path way out of sheet metal or plastic should not be that hard to do, the thing you are going to really put some thought into is how you want to set it up to drain if any water gets in (and if you drive in the rain its going to get in there).
Old May 19, 2010 | 10:52 PM
Brado34's Avatar
Brado34
if i picked this up would it fit on my truck?
http://toronto.kijiji.ca/c-cars-vehi...AdIdZ205315713
I could cut a hole in the side or top.. and possibly mold piping to something like this
http://volant.com/edetail.asp?ID=482
Old May 19, 2010 | 10:56 PM
Brado34's Avatar
Brado34
maby use my current intake box.. cut a hole in the top and lead some pvc piping out of the top so it can be taken off.. attatch ethier a oil funnel type head cut to the piping size. with a round hole below the scoop itself for the intake?
make it fit nice and snug.
Old May 19, 2010 | 11:02 PM
truckin151's Avatar
truckin151
The thing you are still missing is what is going to happen to any water (from rain or snow) that gets into the ram air setup if you ar running it directly to your intake/TB?
Trupiano's Avatar
Trupiano
Why are you worrying about the intake right now? Should prolly just get the hood in work first. Cause anything you decide to do intake-wise, might change if the hood scoop idea doesn't work like you plan.
And like truckin said... DONT GET WATER IN YOUR INTAKE OR YOUR ENGINE! Just had to deal with that issue and it's NOT FUN! Worse case scenario is you bend the intake valves... Don't worry about the ram intake just yet.
Old May 20, 2010 | 08:57 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If I were to do one homemade it would be with 20ga sheet metal and a good MIG with individual beads just like filling doors handles.
