went to start the truck tonight and gremlins and aliens came out from the dash lights
3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
sounds like a pcm problem to me. if it does end up being the pcm, dont let a mechanic charge you $600+ for one. they can be found for $200 or less online. flashed and everything. takes about 5 min to install it. this sounds real similar to when the pcm died on my old durango
i always check my alt by starting the truck and then removing the batt cables, if the truck dies, replace alt... not very technical but has worked evry time
good news I'm back up and running, we replaced the battery as it was original from 03/2005 and got a new one, took the alt with us to the auto parts store and had them check it, it passed, so it went back in the truck
