led tailgate light bar install???????????
Old May 23, 2010 | 12:30 AM
smoker911's Avatar
smoker911
Question led tailgate light bar install???????????
Hey guys
I have a led tailgate light bar
with reverse .I tried to connect the white wire to my reverse lights but the reverse light on the led bar wouldn't light up.what wire should I hook it up to from my trucks reverse lights?,,,,,,,Some Help Please Guys
Old May 23, 2010 | 05:13 AM
RamGentry13's Avatar
RamGentry13
i used my trailer hitch reverse light wire and spliced it into that. worked like a charm
Old May 23, 2010 | 09:23 AM
smoker911's Avatar
smoker911
Default : led tailgate light bar install
OH !! I used the reverse wire from the reverse light in the taillight.Maybe thats why it doesn't work.Which wire is it on the Trailer Hitch?Or do I need to use a light tester to find that out?
Old May 23, 2010 | 11:44 AM
BEAR's Avatar
BEAR
a tester will help to locate the right wire but the wire in the tail light will work if you have the correct one, that is where mine is connected.
Old May 23, 2010 | 12:14 PM
Mega-Hemi's Avatar
Mega-Hemi
Old May 23, 2010 | 01:06 PM
HammerZ71's Avatar
HammerZ71
I'm fixin' to make a little receiver mount light bar for the Jeep for when the winch is not on it, and figure to use it on the rear of my truck at times. Many a time I've gone to load my boat in the bed or load up the ATV at night and couldn't see what the hell I was doing. gonna use a 4 pin trailer wire extender to make a quick connect for attaching for power to the rear of my truck. Already have the PERFECT spot for a waterproof toggle switch too:
To the OP: If you use the 4-pin pig tail, Brown is tail/running, White is ground, Yellow is left turn/brake and Green is right turn/brake...
Old May 23, 2010 | 03:01 PM
smoker911's Avatar
smoker911
Hi'''' there r only 2 wires in the taillight reverse light .1 white 1 black which one .sorry for so many ?? but i don't have my truck right now my wife has it out shopping .so when gets back I'll get to it then..
Old May 25, 2010 | 10:36 AM
smoker911's Avatar
smoker911
Wink Led Tailgate bar
Hey guys""" Thanks for all your input..and fast response.But I got it done today was hooking it up to the wrong wire .I had it connected to the hot white wire in the taillight housing. And it should have been connected to the black ground wire.so anyway it works now so thanks again guys
Old May 25, 2010 | 10:41 AM
black shadow's Avatar
black shadow
I have mine hooked up to the driverside back up light and it works fine
Old May 25, 2010 | 11:20 AM
smoker911's Avatar
smoker911
Smile Led Tailgate bar
Yeah that's what i did to ..now !!!!!!!!
