Help.....Main engine cooling clutch fan.
How do I definatively tell, if my clutch fan is goosed?
My temp gauge is still pegged at one needle width below halfway, on my Hemi engine & there are no funny noises from the engine/clutch fan assy.
But, the fan is easy to stop by hand after several rotations (with a welding glove on) when the engine is fully warmed up and I think the clutch should be fully engaged at this point, to cool the engine.
My reasoning being that the fan should not be slipping and be fully engaged when the engine temp is at normal operating temps, to allow for maximum cooling. I don't think I should be able to stop the fan by hand at this point, or it should be very difficult at least?
Help
Al.
Help
Al.
When I took mine off to do the e-fan mod, I noticed it's obviously turned by the serp. belt and by the smooth side at that. Stopping the fan from spinning on a relatively smooth surface doesn't seem hard at all.
Unless your belt has lost a lot of it's tension, I'd say you don't have a problem. Go out and check, let me know of the results because I'm curious now. Just my
I'm going to let the truck cool fully down and try what the manual said, that I've just read.
I didn't know a test/diagnosis section about the fan was in there??
Apparently, the fan should stop turning after 5 or so revolutions when the truck is completely cold when hand spun..
I stuck my well gloved hand ever so gingerly onto the fan blades a little at a time until it stopped RubberFrog lol.
I do have big B***s though ha ha ha.
Al.
