Noise on stereo when motor is running
Old May 30, 2010 | 07:41 AM
audunfr's Avatar
audunfr
Default Noise on stereo when motor is running
Hello, this may be a stupid question but i try anyway :-)..
I have added a amplifier to my car and been using it to play from my iphone..
Currently my setup has been:
Radio is disconnected from front speakers (Only sound on rear).
Amplifier is connected to front speakers.
This has been working fine, but now i am going on a longer trip and thought i could connect my car stereo to the amplifier so i can enjoy new front speakers and sub together with sound from the rear.
So my first thought was to just take the + and - cable to the front and add a cable back to the amplifier and from amplifier to the speakers.
If i do this everything works as expected when ignition is on, but when i start the car i get a little "bang" and some noise that raises with the cars RPM.
Added a drawing that shows my setup, but its not very good.
Is there something i have overlooked or how can i remove the noise?
Thanks for any answer and again, sorry for my bad English.
Best Regards
Audun
Old May 30, 2010 | 08:24 AM
loflyer2's Avatar
loflyer2
My guess is that there are wires touching, even if they are insulated and not really "wire on wire". Make sure the amp power wire (from the battery to the amp) is not touching any speaker wires. Give wires separate paths to max degree poss. The stronger the amp, the more of a problem this is.
Old May 30, 2010 | 09:11 AM
rcman0056's Avatar
rcman0056
Sounds like you should just buy a new radio for cheap. $60 at the sony refurb store got one with an aux in to plug the ipod in.
Old May 30, 2010 | 09:15 AM
JOHNSN10's Avatar
JOHNSN10
Just make sure ur power cable run on the opposite side of the truck as ur blue power/feed wire and it should be fine
Old May 30, 2010 | 09:18 AM
mike_r's Avatar
mike_r
Is you amp 4 channel, 2 channel or 1?
Old May 30, 2010 | 10:29 AM
Matt99's Avatar
Matt99
They have a noise reducer at radio shack you can tie in, I put them in the boats because its bad on them...
Thats if its engine interference....
Old May 30, 2010 | 10:40 AM
ehoeft's Avatar
ehoeft
i have this same problem if im using an ipod interferance device like the ones you plug into the cigerette liter using the radio stations to play your music. Than i installed an aux jack comming from my navigation unit and i didnt have these problems anymore
Old May 30, 2010 | 10:43 AM
audunfr's Avatar
audunfr
Thanks so much for all the answers.
I did some testing while i awaited reply and come to this conclusion:
I cut a normal 3,5mm jack cable.
Inside that cable its 2 cables, one red another white.
It is also some tiny wires i though was shielding, but when i grounded that to ether the car or stereo (not amplifier) it all disappeared.
All i hear now is a little noise like the one from FM broadcasts, but i can live with that until i add my carputer :-)..
Thanks again, and go dodgeforum!
Old May 30, 2010 | 10:46 AM
audunfr's Avatar
audunfr
My iphone where directly connected to the amplifier with 3,5mm jack plug :-).
I also have a AUX in on my stereo, but the reason i did not use it was because i dident want to do the wiring like i did now :-)..
But thanks any advice is great advice
