homebrew cai with heavy pics - good or bad?
Old Aug 13, 2010 | 01:14 AM
HemiRam1566's Avatar
HemiRam1566
Originally Posted by crazyandy202
Hey where do you get those gromets for the IAT? I cant find them in home depot do you know what they are called and what section you got it in?
and why a filter on the pcv? could i drill a hole in the intake tube and put the pcv hose in there with no filter?
Old Aug 13, 2010 | 01:22 AM
scwpd's Avatar
scwpd
the grommet i used was for a gm dipstick. i cant remember the part number right now. the other tube is a crank case vent tube and you could either run it in the pvc or put a small filter on it. some guys will tell you that you need a vacuum on this line but you don't.
Old Aug 13, 2010 | 01:30 AM
Marx's Avatar
Marx
yep just a breather tube just get a barbed to threaded adapter cut most of the thread off and glue it to the pvc and surcure the hose with a hose-clamp or zip connector
Old Aug 13, 2010 | 04:22 PM
wade0323's Avatar
wade0323
what size PVC is that? Where did you get the adapter?
Old Aug 13, 2010 | 04:50 PM
ekgaudio's Avatar
ekgaudio
Grommet-GM# 65113
Works pretty good but you may need some sillicone to hold it tighter.
