04ram 4.7 v8
Old Jun 3, 2010 | 08:47 PM
kimber's Avatar
kimber
Default 04ram 4.7 v8
my ram stalls after it starts to warm up, will shut off sometimes when coasting to stop then starts up on its own. what can be wrong?
Old Jun 3, 2010 | 08:54 PM
chambers's Avatar
chambers
Your truck starts itself back up after it stalls? Look at the IAC on the throttle body or it could also be the EGR. Try pulling the IAC motor off the TB and cleaning it, that might be all it needs.
badblackram06's Avatar
badblackram06
how many miles do you have on it? i talked to a guy with an 03 4.7 that was stalling out like yours and it ended up being in his throttle body. Is your Check engine light on?
Old Jun 3, 2010 | 09:23 PM
kimber's Avatar
kimber
no check eng. lite on scanned system no codes at all,
also as i'm coasting to a stop or up a hill it shuts down, tack goes to 0 and gauges are off till it starts up again with-in seconds.
Old Jun 3, 2010 | 09:24 PM
kimber's Avatar
kimber
also it has 53,000 miles.thanks
Old Jun 3, 2010 | 09:25 PM
cwboyjohnny24's Avatar
cwboyjohnny24
Clean the throttle body and look also at the throttle position sensor. I would lean towards that.
Old Jun 3, 2010 | 09:36 PM
kimber's Avatar
kimber
did clean thottle body this morning wasn't bad, didn't help.
Old Jun 3, 2010 | 09:42 PM
cwboyjohnny24
Did you try to do the reset on the throttle position sensor?????
https://dodgeforum.com/forum/3rd-gen...e05ram360.html
https://dodgeforum.com/forum/3rd-gen...procedure.html
Old Jun 3, 2010 | 09:50 PM
kimber's Avatar
kimber
no ,how to u reset it?
Old Jun 3, 2010 | 09:51 PM
cwboyjohnny24
Look at the links I just posted at #8.
