Throttle body problem?
Old Jun 6, 2010 | 12:14 AM
mike_dmt's Avatar
mike_dmt
Default Throttle body problem?
My truck died a couple of times yesterday so checked the obd, and posted the codes 2106 and 2108 this morning in another thread. Everyone recommended that I clean my throttle body really good.
Did that, and started it about 20 times in the shop. Let it idle for a bit, drove it around the block a few times, all good. But after driving about 4 miles, shut it off, and it wouldn't start for about 45 minutes. Got it back home, shut it off, and wouldn't restart again.
Now its about 4 hours later, starts right up. So I'm thinking the throttle body must be failing once the engine bay gets hot???? Anyone heard of this? Wheres the best place to get a new one? I dont really want to go to the stealership...
Old Jun 6, 2010 | 08:46 AM
bwdakrt's Avatar
bwdakrt
Depending on year model and engine size, sounds like you may have an ignition coil that's getting hot and shutting down the spark.
Old Jun 6, 2010 | 03:37 PM
mike_dmt's Avatar
mike_dmt
Would it shut them all down? This doesn't sound consistent with what I've read up on this board.
In a couple of my other posts I mentioned the ETC light flashing, which usually points to the TB I thought..
Any other ideas?
Old Jun 6, 2010 | 09:13 PM
bwdakrt's Avatar
bwdakrt
Any other ideas?
This could be the problem if you have the 3.9, 5.2 or the 5.9 due to having a single ignition coil. If you have the 4.7 with multiple coils, this would not pertain to your engine. That's why I said "depending on year model and engine".
Old Jun 6, 2010 | 11:31 PM
mike_dmt's Avatar
mike_dmt
Sorry. It's 5.7 Hemi. Thats why I was confused. It has 8...
Old Jun 7, 2010 | 08:08 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
What year is your truck? Ive got 2 TB's sitting on the floor I was going to use for porting but wont be doing that. LMK what year you have and if you still need one.
