just picked up my truck and......
Sso i just brought home my new to me 2007 ram 1500 sbrc 4x4 hemi with 70,000kms on it.. everything was good then this morning i started it up went for a drive and "gascap" came up on the dash,
Figured i did not tighten the cap enough so i went out and gave it a few more "clicks" so i continue driving hoping it would go out then the engine light came on and i figured the "gascap" on the dash would throw a evap code and set the engine light on. so that wasn't shocking.. went to my shop hooked the scanner up and it had a evap code small leak detected (generally a gas cap) so i tested the cap on the etest machine it passed.. the other code was evap module malfunction. so i cleared all codes all lights went off.
now every time you start the truck "gascap" comes up on the dash but no engine light. You hit the trip button it goes away and it wont come back on until you start the truck the next time.. any ideas?
I guess its going back to the dealer tomorrow..
all i want to do is drive the truck i love it
thanks
connor.
all i want to do is drive the truck i love itthanks
connor.
check the hoses that go from the filler neck to the charcoal evap canister, and also the hoses that run toward the front. if any of them are cracked at all, replace them.
I was having the same problem with my truck before it got stolen. I had changed gas caps cleared the codes I even changed an o2 sensor. Go luck fixing it and let us know what you find out in case we start having the same problem
thank for the replies.. im taking it back to the stealership today and they can deal with it. hopefully they do a smoke test figure out what the issue is and then fix it.
thanks
connor.
thanks
connor.
thanks
connor.
connor.
nice truck i hope u get it figured out nice to see another 07 reg cab 4x4
thanks "tsnyder" i like your dual side exit exhaust.. is that a custom set up? or is it a kit, are you running mufflers? if so what kind? i would like to run a set up like that in the future.
thanks
connor.
thanks
connor.
Trending Topics
its magnaflow si/do 3'/2x3'' with 12" ss tips beware it is major loud and i get hardcore cab drone it actually shakes the change in my change dish!!!! i cannot wait to get my headers....if i was gonna do it any other way id run them out the back not angled but at 90 deg angles would look nice there is a kit u can get like mine its on the magnaflow site
