03' 360 cams?
Old Jun 7, 2010 | 09:47 PM
rollingdodge's Avatar
rollingdodge
like the bbk 52mm? thats the only one i have ever found. do you know where i kind find more if there are any?
Old Jun 7, 2010 | 09:53 PM
98cherryram's Avatar
98cherryram
BWdakrt did a really good one, but hes done now, so the fastman is probably the most highly recommended, thefastman.com
Old Jun 8, 2010 | 12:52 AM
rollingdodge
the 50mm or 52mm? any suggestions?
Old Jun 8, 2010 | 01:58 AM
98cherryram
50 is suggested for towing, 52 for top end, I still suggest the 50 though... I am very happy with my 50!
Old Jun 8, 2010 | 07:57 PM
lastrights's Avatar
lastrights
1.7 hs rr
Old Jun 8, 2010 | 08:06 PM
nim81's Avatar
nim81
Originally Posted by lastrights
1.7 hs rr
+1,000,000
Old Jun 8, 2010 | 09:40 PM
talon6's Avatar
talon6
intake,exhaust(with headers)and throttle body are just about a must with any cam upgrade. i mean you donnt have to, but you wont see the full power of the cam unless you do.
if you go with the 210 you need to get a new torque convertor with a higher stall too. and yes a tune from hemifever(sct).
and about the 1.7 roller rockers. there is a gain there, but if i had to do it all over again, i would just skip them and go with a cam.you can get a cam for the same price as the rockers. but there is alot more work with installing a cam.
and i would suggest the fastman 52mm for you. you said you were looking for more top end.
Old Jun 9, 2010 | 12:47 AM
98cherryram
So you dont think I should do the 1.7 rr's talon? I thought there was a lot more cost involved with a cam...? Like I thought you had to do a whole bunch of stuff to be able to do a cam... like replace a bunch of parts...
Old Jun 9, 2010 | 07:36 AM
rollingdodge
no i talked to krc about the 210 cam and they said you can run everything how it is, all you new is a tune. i dont have headers yet but i was going to get some in the future. and they said that they will re-tune it for free up to a year.(thats krc)
so could i run 1.7rr with the 210 cam?
Old Jun 9, 2010 | 11:46 AM
Shiloh 24's Avatar
Shiloh 24
I was under the impression that with the stock valve covers you couldn't clear the rockers and a cam because of the higher lift, it would impact the cover.
