Body Lift ??
Old Jun 8, 2010 | 09:48 PM
mattg1500's Avatar
mattg1500
Default Body Lift ??
I have an 05 1500 4wd. anyone install their own 3" body lift? any problems doing it in your driveway?
Old Jun 8, 2010 | 09:53 PM
AF_HEMI's Avatar
AF_HEMI
i havent on my ram, but i did on another truck. from learning the experiences of MANY members on here, its not hard to do in your driveway. the only part that gives a little bit of trouble can be the steering extension. if you unbolt the steering column from the dash (2 large hex bolts), it should slide freely allowing enough space to slide in the extension peice.
Old Jun 8, 2010 | 10:26 PM
RubberFrog's Avatar
RubberFrog
Piece of cake. Unbolt the steering extension BEFORE you lift the body and it will pop right out.
http://www.youtube.com/watch?v=nHe0NxD545E
Old Jun 9, 2010 | 12:51 AM
98cherryram's Avatar
98cherryram
I did a 1 inch bodylift in my garage in about an hour... I didnt need a steering extension though.
Old Jun 9, 2010 | 06:39 AM
AF_HEMI's Avatar
AF_HEMI
Honestly theres only a little additional time needed for 3" vs 1". Unless you're really opposed to it, its my opinion to get the most lift for the work.
Old Jun 9, 2010 | 07:34 AM
HammerZ71's Avatar
HammerZ71
Although it's been 12 years since I've installed one, I've done three on my own trucks and two on other peoples through the years. Every one with the use of a jack and jack stands.
Some have taken me a full day, some a full weekend, but nothing too difficult to do...
Old Jun 9, 2010 | 05:13 PM
mattg1500's Avatar
mattg1500
where did you find a 1" body lift?
Old Jun 9, 2010 | 08:25 PM
98cherryram
I had to buy the blocks and the bolts seperate, they dont sell a 1 inch kit so you have to make your own basically. It was real easy though, but its like AF said, if you dont care then go for the 3, there isnt much more work for 3 over 1. I just dont like big noticeable body lifts...
Old Jun 9, 2010 | 08:29 PM
AF_HEMI's Avatar
AF_HEMI
^^ they arent noticeable if you get wheel liners
Old Jun 10, 2010 | 04:59 PM
mattg1500's Avatar
mattg1500
My only concern is wiring for my stereo going through the firewall and also in the vid from rubberfrog, they had to do some cutting for the front bumber
