very light surging
Old Jun 8, 2010 | 10:11 PM
svkb's Avatar
svkb
Default very light surging
Hi guys, I searched but couldn't find exactly what I was looking for. Lot of threads with engine rpm surging or almost stalling but that's not the issue I'm having.
Basically, when I lightly accelerate I feel a very light surging. The rpm doesn't surge or anything and it has never stalled or even felt like it was going to stall. When I accelerate hard it is fine.
At idle in gear it runs at about 550 rpm.
It's a 2005 QC hemi and has done this since I bought it 2 months ago. I also recently changed the plugs and cleaned the throttle body. Every other thread that came close to my symptoms was the result of a faulty egr valve.
I doubt that it has ever been changed and it has 80,000 km's on it.
What say you experts? EGR valve or something else?
Old Jun 9, 2010 | 12:27 AM
svkb's Avatar
svkb
I should mention that it is not throwing up any codes right now.
Old Jun 9, 2010 | 12:29 AM
nh5's Avatar
nh5
possible vacuum leak (check hoses), if its the egr give a while and it should eventually throw a code. It wouldn't hurt to change out the EGR also since its gonna die eventually.
Old Jun 9, 2010 | 07:38 AM
tsnyder's Avatar
tsnyder
Wow i have had the same issue for along time i did all these things replaced plugs/cleaned tb many times/cleaned pvc valve replaced egr valve reset pcm also all in 1 shot and it still does it i took it to a dealership and even got there head mech to drive the **** out of it and he said about resetting the pcm but still prob not solved i might have to take it back to them and harras the sh&* out of them send me a pm if u find out what it was
Old Jun 9, 2010 | 03:50 PM
RamGentry13's Avatar
RamGentry13
i was just gonna post up a new thread when i saw this one. my truck, tho a 4.7, is displaying many of the same symptoms your describing so im gonna bump this thread and see if we can get any other answers. As mentioned before i feel a light surging usually when cruising at a constant speed, typically between 30-60 MPH, and have no idea what the prob is. There doesnt appear to be RPM change (i dont see the needle jumping around while its surging) and im not throwing a code. All fluids are good, TB is clean, sparks are new and gapped correctly...im a lil lost. The surge feels almost like riding over a wavy road, just a slight jostle but its noticeable. Im hoping it is something to do with EGR or something simple. Sorry for being long winded but i obviously want this resolved.
Thanks in advance!
Old Jun 9, 2010 | 04:57 PM
svkb's Avatar
svkb
Anybody priced out an EGR valve in Canada? Where is the best place to get one?
Old Jun 9, 2010 | 05:22 PM
andrew67's Avatar
andrew67
Mine has done it since i bought it new. Seems like it only really does it when its cold and then goes away.
Old Jun 9, 2010 | 08:58 PM
svkb's Avatar
svkb
I kind of noticed that today as well, it seemed to get better as the truck warmed up. But I couldn't tell if it was just my imagination or not.
Old Jun 10, 2010 | 11:55 AM
RamGentry13
i dont notice much of a difference between cold and warm, it does it either way. still noone else with this problem that has found a fix?
