04 Ram 1500 4x4 grinding noise
Old Jun 10, 2010 | 01:32 PM
ladidadi's Avatar
ladidadi
Default 04 Ram 1500 4x4 grinding noise
Hey all, I never really post on forums i mainly use them for information but I really need some help. My truck is making a popping noise right under my feet when I turn left but not when I turn right. It is also grinding so bad that I am embarrassed to drive it even with tinted windows. Here is everything that I have had replaced today.
hub assy.
front brakes and rotors
the drive shaft coming out of the transfer case
steering rack
What else could it be? I am thinking it could be the driveshaft or transfer case. Also what else can I do to trouble shoot it.
Old Jun 10, 2010 | 02:13 PM
jeepdude's Avatar
jeepdude
does it sound like a metal on metal grinding......
Or a Rubber on body grinding??
Old Jun 10, 2010 | 02:56 PM
ladidadi's Avatar
ladidadi
It sounds like a metal on metal sound. Also it doesnt do it right away it takes it a little to start but when it does it is bad.
Old Jun 10, 2010 | 04:35 PM
jeepdude's Avatar
jeepdude
wheel bearings???
Old Jun 10, 2010 | 05:25 PM
ladidadi's Avatar
ladidadi
I replaced the full hub assembly. This included the wheel bearings
Old Jun 10, 2010 | 05:36 PM
jeepdude's Avatar
jeepdude
hmmmmmmmmmm.... Damn i wish i could hear it.
Old Jun 10, 2010 | 05:51 PM
ladidadi's Avatar
ladidadi
Well I know that the problem has to be from the transfer case back because i have replaced everything that spins from the transfer case to the tire.
Old Jun 10, 2010 | 06:20 PM
svkb's Avatar
svkb
What about front CV joints. I've had several go bad and it starts out making noise only when you turn.
Old Jun 10, 2010 | 06:21 PM
james.shinevar's Avatar
james.shinevar
I had some random popping sounds from under my dodge and it turned out to be the U-Joint. One side had all the needle bearings wiped... it looked horrible
Old Jun 10, 2010 | 07:26 PM
ladidadi's Avatar
ladidadi
Was this on a 4X4 because I think it might be the front u joints. That honestly sounds like the problem. How would i go about checking them out without removing the drive shaft
