04 Ram Stalling at stops or slow downs
Old Jun 10, 2010 | 08:54 PM
2000vikings's Avatar
2000vikings
Default 04 Ram Stalling at stops or slow downs
Hello all, I recently started having a random stall and complete shut down of my truck at times when I am coming to a stop or slowing to turn. Scared me a little as I couldn't steer or brake very easy. That being said, I have researched and found it is likely needing a new EGR valve, but the problem is my year truck does not actually have an EGR valve. I have the 4.7l and it should be located on the back of the drivers side cylinder head, but it is not installed (never was for this year and early). That being said, any ideas on what would be causing the issue? Any help would be greatly appreciated.
Old Jun 10, 2010 | 09:13 PM
kimber's Avatar
kimber
have stimuler problem my 4.7 04 stalls when it warms up for aleast 25-30 min. in park, and has stop running and then starts up while coming to a stop. tried cleaning sensors and thottle body and still does it , no codes.
Old Jun 10, 2010 | 09:24 PM
Marx's Avatar
Marx
try a new battery i had some weird stuff happen with my oe battery, stalls and stuff, these trucks don't like low voltage
Old Jun 10, 2010 | 10:25 PM
RubberFrog's Avatar
RubberFrog
Start with the basic tune up stuff- plugs, air filter, clean the TB, clean/replace pcv valve (if you have one). Test your wires with a continuity meter.
Old Jun 11, 2010 | 06:31 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Check the trans fluid level also
Old Jun 23, 2010 | 12:41 PM
timtim2008's Avatar
timtim2008
i have same problem, 03 4.7lt.. does it on startup sometimes too. fine when i keep giving it gas, but at stop signs it stalls.. no codes
Old Jun 23, 2010 | 01:20 PM
brettj2408's Avatar
brettj2408
check your charging voltage and static voltage of the battery. your VR in your alternator could be slowly dying.
Old Jun 23, 2010 | 01:25 PM
brettj2408's Avatar
brettj2408
Old Jun 23, 2010 | 01:36 PM
Brock_USMC's Avatar
Brock_USMC
I had this same exact problem a couple months ago. I got a new battery and haven't had a problem since. You could try that sea foam stuff too, from what I hear it works miracles.
Old Jun 23, 2010 | 01:41 PM
cwboyjohnny24's Avatar
cwboyjohnny24
I would also say look at your tps (throttle position sensor). I had a 99 ranger that used to shut down when I came to a stop or slowed down for a corner. Replaced the tps and problem went away. You could also see if recalibrating it would help a little.
