cheap way to gain horse power
Old Jun 13, 2010 | 05:15 PM
  #21
Got_Hemi44's Avatar
Got_Hemi44
Originally Posted by hemiguy0302
Does anyone have actual RWHP numbers to prove the flowmaster hurts anything? Untill then I still call bullchit
The fact flowmaster has V shaped baffles that cause disruption in air flow compared to straight mufflers like magnaflow?
O, and the thousands of various vehicle owners across the world who noticed decrease in performance with flowmaster.
Old Jun 13, 2010 | 07:29 PM
  #22
MikeHTally's Avatar
MikeHTally
Stickers and wings.
Old Jun 13, 2010 | 07:41 PM
  #23
hemiguy0302's Avatar
hemiguy0302
I wanna see numbers. Word of mouth mean pretty much **** all to me when I'm dropping bills on performance parts. Its why I have not bought a converter yet. No numbers I can find to justify the purchase. Same thing with **** like a power wire. Unless I have concrete proof it means jack all.
Old Jun 13, 2010 | 08:11 PM
  #24
oefootball_70's Avatar
oefootball_70
here is a kinda updated list. there are things that are not on the list that have done good and there are things that should be rearranged on the list as well.
NO on the throttle body spacers. They are meant for a carburetor motor. I would recommend
1. Ported Throttle Body
2. Cheap things like E-Fan, and a new Y pipe. TMR mod is free do it. (use the search function)
3. Headers, only option is shorties for the 4.7
4. I would then do Superships. I am not sure how much difference you would see being a stick and although they do do SOME motor tuning. They focus on the Trany
5. If thats not enough Gears, (The gear choice will depend on what size tire you are going to run most likely a 4.10 or 4.56)
6.2008 H/o intake manifold
7. Under Drive Pulley
8. Then a Torque convertor
9. Then Ported and polished heads
-While you are doing this you might as well do cams, high lifting springs and all those goodies
10. CAMS
-KRC is now offering full billet cams with LSA ranging from 116 to 106
11. Now that you have a cam and new heads you are going to need a custom tune. I would only recommend one tuner for the 4.7 Hemifever
12. For you custom tune you will need a wide band gauge and maybe a couple others to get the info he will need to tune you correctly.
13. If this truck is still not enough for you I would look into a lowering kit to run smaller tires
14. At this point if you still need more the only option is to leave the world of N/A, and at this point you have 3 options
1. NOS-has been run on a 4.7 before that ran good times
2. Turbo charge, KRC is selling a kit with everything you need 2-3k
3. Supercharge, you will be hard pressed to find one. They made one
years ago for the 4.7 but discontinued it. You will see them come up
for sale every now and again.
This list is just my opinion over what I have heard, learned, and witnessed working over the years. If I am not clear or you got any questions post it up!
Old Jun 13, 2010 | 08:34 PM
  #25
Got_Hemi44's Avatar
Got_Hemi44
Because you know we all spend our money on things that don't work.
Old Jun 13, 2010 | 08:41 PM
  #26
hemiguy0302
Braggadocio. The phenomenon that occurs when admittance of total satisfaction is expressed after several hundred dollars have been spent even though results may have been disappointing. Its not that I do not trust people I just wanna see actual values that are numbers not well this is way better than before comparisons if you know what I mean.
Old Jun 13, 2010 | 08:48 PM
  #27
truckin151's Avatar
truckin151
You must not do a whole lot of research when it comes to performance parts then.... Ask ANYONE who runs their truck at the track the ET difference between running a stock converter and a performance converter. Most have a claim of a 6-8% improvement over the stock drive train's parasitic loss, netting you around a 20-25hp gain. But the real facts are not in hp numbers alone, its in the track ET's.
To the OP - What are you goals for the truck? Are you going to run it at the track? Just looking for a little extra pep for day to day driving?
Old Jun 13, 2010 | 08:55 PM
  #28
hemiguy0302
Ok 151. Humble pie is being eaten.
/searches for 1/4 times now.
Old Jun 14, 2010 | 02:56 AM
  #29
287cc's Avatar
287cc
Im not a a fan of flowmasters for performance myself. Looking at the internal design of those mufflers, its very restrictive even the oem muffler is desgined to flow better.
