T-bar cranking and alignment
Old Jun 20, 2010 | 05:29 PM
mattwv88's Avatar
mattwv88
Default T-bar cranking and alignment
I cranked my t-bar and rasied the front end just one inch. Went from 37 inches to 38 inches. I don`t need a front end alignment now do I?
Old Jun 20, 2010 | 05:33 PM
AF_HEMI's Avatar
AF_HEMI
yes you do. dont drive long without getting one. it should be the next top priority
Old Jun 20, 2010 | 05:36 PM
ramhunter9's Avatar
ramhunter9
1 inch will cause things to wear out like tires cupping and end links and ball joints .
rule #1 about a level ......get a alignment
rule #2 get longer shocks ...but in your case 1 inch you will not need longer shocks 2 inch or more yes you do unless you like a crap ride .
Old Jun 20, 2010 | 05:37 PM
Big_Wheel's Avatar
Big_Wheel
i went 2.5 inchs above stock. put on 35" tires ..and didnt see any signs of tread wear until 6 months later.. and i drive 60-75kms a day. went a year after that and my tires where fine...mind you they were 35" offroad tires so i didnt care that much. Truck didnt wonder at all on the highway.
Switching up tires now and bought a new set and will be gettin an alignment done.
ITs really up to you if you want one or not---how much do you care about your tires? lol
Old Jun 20, 2010 | 06:32 PM
donjohnk's Avatar
donjohnk
well Ill say this. I regret not getting mine aligned... I cranked mine up 1.5" and not doing any research now I am having issues with a tie-rod or ball joint noise.. Also I dont know if this would be a cause of it but my steering rack is leaking pretty bad.. My tires dont show any sign of bad wear.... I only put 15k on the truck since I played with the t-bars. Now I have to play fix it and wonder what else is wrong.
Old Jun 20, 2010 | 06:35 PM
ramhunter9's Avatar
ramhunter9
yup you mess with suspension componints you get a world of trouble ..unless you do it correctly the first time .
Old Jun 20, 2010 | 07:42 PM
mattwv88's Avatar
mattwv88
Thanks guys!
Alright here is my thing. I am wanting to get a rough country lift. But money being a problem I am trying to talk my self out of it and just buy a leveling kit. But I know that the lift kit would look way better, give me allot more off road clearance, since it comes with new shocks it would ride better and it would let me put bigger tires on. Can anyone think of anymore reasons to get the lift? Also I am worried about MPG loss due to the lift. The rough country lift is 1195 plus shipping and the leveling kit is 99 bucks. I know if I get the leveling kit that I am going to want new shocks as well. What would 4 good shocks cost me?
Thanks!!!
Old Jun 20, 2010 | 07:46 PM
ramhunter9's Avatar
ramhunter9
save your money and get a lift . you will regret the level over time . you say you off road ? if thats the case suspension lift is the only way IMO .
Old Jun 20, 2010 | 08:21 PM
mattwv88's Avatar
mattwv88
I don`t off road allot but when I do it sure would be nice to have a lift!!
I am going to take your advice. I will save for the lift. Should I get the Rough country with the 2 or 3 inch blocks? Is there any good reason not to get the 3?
Old Jun 20, 2010 | 08:30 PM
ramhunter9's Avatar
ramhunter9
the 3" blocks will get you back to factory rake . IMO if you tow or haul anything you need the rake to level out the truck . if you dont do any of the 2 then 2" blocks will level the rig
