no power hemi
Old May 16, 2005 | 11:25 PM
barnburner69er's Avatar
barnburner69er
Default no power hemi
i just found out yesterday that i cant do a smoke show with my truck 2004 ram hemi -sometimes i can but not to often dodge service says computer wont let me is this true??? what if i get stuck in mud my max rpm will not go over 2000 ?? very troubled are all hemi trucks like this??
Old May 16, 2005 | 11:56 PM
moparturd's Avatar
moparturd
Default RE: no power hemi
Welcome to Dodge Forum. I've not tried to burn them down so I can't give you any firsthand experience, but I have heard this before.
Old May 17, 2005 | 12:00 AM
barnburner69er
spent $45000 on a toy i cant play with! but there must be some way to overcome this . how do guys warm up tires at the track????
Old May 17, 2005 | 12:18 AM
moparturd's Avatar
moparturd
Hold the brake and run up the rpm's.
Old May 17, 2005 | 12:32 AM
DonG's Avatar
DonG
If your truck won't go over 2000 rpms in the mud you have a serious problem with your truck. Mine won't smoke the tires on dry pavement, but launches very fast. Spinning tires is a disadvantage.
barnburner69er
engine has some kind of govenor on it that wont let it rev up if the wheels are not in sync with the call for power and at 2000rpm the wheels wont spin but thanks much for your infinate wisdom
Old May 17, 2005 | 12:36 AM
barnburner69er
if someone like me wants to peel the tires off the rims then i should be able to 345 laughs on the drag strip
Old May 17, 2005 | 01:04 AM
osteodoc08's Avatar
osteodoc08
This is due to the Torque managment system. Do a search and you should find some more info.
Old May 17, 2005 | 01:50 AM
HemiRam11's Avatar
HemiRam11
i can definetly burn em up on dry pavement in stock form. hold the brake all the way down get in the gas a little let the brake out slightly till it starts to spin then fully depress the brake once more
Old May 17, 2005 | 02:46 AM
vipersforsale's Avatar
vipersforsale
I am with DonG on this one, there must be something wrong with your truck, because I have no problem peeling out even when I am not trying to with my truck and its an '04 with a hemi and 20's even. If I floor it from a dead stop it will just keep spinning till it catches up in speed with the tires... terrible for a good launch for sure!
