Custom End Links
Old 06-24-2010, 11:25 AM
RubberFrog's Avatar
RubberFrog
RubberFrog is offline
Default Custom End Links
I bought these from a member on another forum a month or so ago. They were a little too short for my lift so I had to buy new 5/8 SS rod to lengthen them a bit. I finally got the rod in yesterday, cut it to the length I needed, and got them reassembled. It was a bit of a surprise this morning when I realized I had to drill out the lower control arm to accomodate the larger stud mount (thanks for the heads up...). A little cutting fluid and low rpms went right through it in a matter of minutes.
So here they are. What do you think?
Old 06-24-2010, 11:31 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Nice, I forgot you had those crossmembers dropped too.
Old 06-24-2010, 02:38 PM
cwboyjohnny24's Avatar
cwboyjohnny24
cwboyjohnny24 is offline
Sweet. Did you put rubber bushings on the ends to avoid metal on metal? I'm asking because wouldn't that start making noise if it moves just a little?
I do like that setup though. Very creative.
Old 06-24-2010, 02:41 PM
OlDirtyJohn's Avatar
OlDirtyJohn
OlDirtyJohn is offline
awesome! wish i could find some better end links. no one makes anything aftermarket for 2wd though.
Old 06-24-2010, 03:08 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Someone posted a link to a company who makes some better links. I forget the person and site though. They were nice but still not as good as the ones RF had. And come to think of it, arent these in this thread Kore end links?
[EDIT]
Nevermind, i found them.
KORE Dodge Ram End Links 1994-2009 4x4, 2500-3500, 0-3" Lift
KORE Dodge Ram End Links 1994-2009 4x4, 2500-3500, 3-6" Lift
Old 06-24-2010, 03:10 PM
ramhunter9's Avatar
ramhunter9
ramhunter9 is offline
i used suspension maxx links on mine warranty for life . and weed that would be me
Old 06-24-2010, 03:16 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Yep, thats right. Those are the one and thanks for chiming in and reminding me.
Old 06-24-2010, 03:37 PM
Big_Wheel's Avatar
Big_Wheel
Big_Wheel is offline
do you know if they make them for the 1500 or do you have to make them yourself?
Old 06-24-2010, 03:45 PM
RubberFrog's Avatar
RubberFrog
Weed catches everything. Mine are kore endlinks. They're the ones in the second link with an extra set of mounts on them.
Old 06-24-2010, 03:53 PM
RubberFrog's Avatar
RubberFrog
I didn't use any bushings. If they make any noise, I will order some urethane washers from mcmaster carr to deal with it.
Quick Reply: Custom End Links
