2007 Dodge ram towing help
Old Jun 25, 2010 | 08:12 PM
Ram 07 4x4's Avatar
Ram 07 4x4
Talking 2007 Dodge ram towing help
Hey guy's , After the family's last camping trip (tent) we have decided to get a camper and i need to start putting the pieces together of what i might need to tow a trailer safely were thinking a mid sized trailer not sure on the footage but once i get a idea of the weight i can go from there.
2007 dodge ram 1500 4x4 4.7 L v8 gears unknown how do i find this info the vin # ??
I have never towed anything other than a car trailer so its gonna get interesting lol
also it didn't come with the tow package so theres no hitch .
Old Jun 25, 2010 | 09:06 PM
blakeroberts88's Avatar
blakeroberts88
http://www.dodge.com/towing/D/home.html
Check out the above link. It is a towing guide for Dodge vehicles. Your truck either has the 3.55's or 3.92's. If it didn't come with the tow package then it most likely has the 3.55's. They will still do the job for towing stuff it would just be much easier with 3.92's.
Old Jun 25, 2010 | 09:20 PM
magnethead's Avatar
magnethead
Ours came with towing package, 3.92's.
For a 4.7 1500, i would definately say that you're require a 5th wheel, gooseneck, or weight distributing hitch. A standard bumper pull won't work. Oh, and trailer brake also required. Literally- Down here in Tx at least, you have to have any trailer with living quarters annually inspected just like your truck, and part of that inspection is a trailer brake test. IDK how other states are.
With our racecar, it weighs 2800 pounds, the trailer is 2200 pounds, and we load a safe-guessed 500 pounds of stuff in the bed. For the 6 miles to the local strip, we're riding solidly on the rear bumpstops, and almost on the fronts.
Old Jun 25, 2010 | 09:39 PM
blakeroberts88
All he really needs to do is install a Class IV (10,000 lb) receiver with Weight Distributing hitch.
Ram 1500's are not good for 5th wheels. I've seen it done but they had air bags or some thing to help out. 5th wheels still aren't recommended since most 5th wheel trailers surpass the weight limitations on our 1/2 ton trucks.
Old Jun 25, 2010 | 09:42 PM
Ram 07 4x4's Avatar
Ram 07 4x4
Default ?
How can i find out for sure what gears are in there ?
Old Jun 25, 2010 | 10:02 PM
blakeroberts88
Check on the rear diff. or the glove box. If you cant find anything there then try bringing it to a dealership, giving them the VIN and they should be able to get you the build sheet for it. But if it didn't come with the tow package then most likely it has the 3.55's.
Old Jun 26, 2010 | 02:39 AM
Philav's Avatar
Philav
One way to find out if you have a 3.55 gear is cruze at 65 and if your tach is at 1800 rpms, you have a 3.55.
Old Jun 26, 2010 | 11:53 AM
ohio1500ram's Avatar
ohio1500ram
My 4.7 2004 Ram with the Towing package has 3.55 gears....Thats kind of Odd, I with it had 2.73 or something for some better mileage!
Old Jun 26, 2010 | 12:01 PM
flwalks's Avatar
flwalks
My 2007 4.7l didn't come with tow package and has 3.92 gears. Look on the rear axle and there should be a tag with gears and if it is open or no spin. Look in the glove box for the paperwork (window sticker) from when it was new. The dealer puts it with the owners manual.
Old Jun 26, 2010 | 01:19 PM
Ram 07 4x4's Avatar
Ram 07 4x4
Default Thanks
I will try the things yall have said thanks again will update when i find out
