Last edit by: IB Advertising
Browse all: Electrical Guides
- Dodge Ram 2002-2008: Fuse Box Diagrams
Important information to help you understand your Ram
Need Help on my parking lights
Found this...
http://board.moparts.org/ubbthreads/...Number=7444228
Going to get started on it tomorrow afternoon..
That’s thread shows him replacing the relays. Your problem is most likely corrosion on the board. You will know when you take it apart if you see corrosion on it, then your relays are not the problem. If you don’t want to take it apart you can add a new relay to your head lights and have your parking lights come on with the headlights only. But hey will not work as parking lights only after.
Unable to Download Pics from Rought.
Common problem especially if you hose down your engine compartment with water . I managed to disassemble the fuse box (power distribution center) on my 2004 and clean off the corrosion, then repair the bad connection with a jumper wire see pics. after that I sprayed clear lacquer paint around the problem area to protect it.(or silicone sealant would work) (making sure not to get clear on the connections). also you can jump the lights at the relay giving the relay alt power were its not getting it do to the short. hooking up a new separate relay the comes on when you turn on your main headlights then run from the new relay to the old relay. lamps will be on when your headlights are on only,, but it works. you can just do that, then clean the circuit board in the fuse box and protect it from further corrosion cuz soon,, it will get worse and most likely loose your instrument panel lights next,, then so on.
Or just get ripped off and pay $400 plus for a new one.
Uploaded with ImageShack.us
