Tire Balancing
nh5, Since you said your steering shakes then I cannot suggest that your CV half-shafts are worn out (4x4). You say after a rebalance they are good then it shakes again. There is an old school way to prove the tires are shot that I've used in the past (I.E. Sears Brand Michelins) When and if your symptoms appear (truck starts to shake like you mentioned) remove the two front tires and cross them over to the back (x pattern) and then move the back ones straight up to the front. Go for a test drive and if the shaking goes away the 2 front tires are confirmed shot. If that is the case the ones you placed on the front will probably prove to shake within 5 to 6 hundred miles too.
