Project Done! 12V Cummins in an 03 1500 functioning like OEM
3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
The easy parts were the general install. The wiring and understanding signals that it needed were the brain beaters. The driveline was shortened 2 or 3 inches (can't remember now) sleeved the front and installed it directly to the 48RE. 4" exhaust is a little tight, but cleared without beating anything around. Intercooler tubing is one piece on each side (Ben's creation) that cleaned up the install greatly. Hated to show off under the hood before getting the paint applied and choice items polished but oh well. A/C lines were a little tricky but they appear to be made by Dodge for the truck once we were done. Thanks for all of the compliments!
Def some good work done there! Nice job.
Did you use the stock 9.25" rear end?
How about the front suspension, did you make any changes to accomodate the extra weight?
