tow hooks
Old Jul 10, 2010 | 11:38 AM
outcast's Avatar
outcast
Default tow hooks
my o2 dodge doesnt have front tow hooks and im wanting to put some on. i like the heavy duty loop style like in the 3/4 tons but the only ones i can find for a half ton is a gay lookin bar with two little hooks on it. y wont the 3/4 ton style bolt on a 1/2 ton or will it. any ideas?
Old Jul 10, 2010 | 11:49 AM
dirtydog's Avatar
dirtydog
Moderate User
Because the frames are different. Your stuck with the happy looking bars unfortunately unless you can make your own?
Old Jul 10, 2010 | 12:33 PM
outcast's Avatar
outcast
but the tow hooks dont bolt to the frame they bolt to the bumper bracket which bolts to the frame the same way as a 1/2 ton so would all i need to do is buy the 3/4 ton bumber bracket
Old Jul 10, 2010 | 12:49 PM
dirtydog's Avatar
dirtydog
Moderate User
Then how would you mount the 2500 bumper bracket to the 1500 frame? the bumper brackets are different because the frames are different.
Old Jul 10, 2010 | 03:58 PM
outcast's Avatar
outcast
the brackets are the only thing that are different they bolt to the frame the same way the 1/2 ton has three holes in front to mount the tow hook bar the 3/4 ton bracket has four holes for mounting the tow hooks thats the only difference
Old Jul 11, 2010 | 08:15 AM
Sheriff420's Avatar
Sheriff420
Why not just make a front hitch and throw a shackle in it?
Originally Posted by fk1022
ok here you go, NO MORE PIC'S FROG...
Old Jul 11, 2010 | 08:19 AM
HammerZ71's Avatar
HammerZ71
or even buy a front receiver hitch if you don't have the resources or skill to make one. Can be purchased for not much more than the Mopar tow hooks and is a hell of a lot more versatile...
Old Jul 11, 2010 | 08:55 AM
TRXHemi's Avatar
TRXHemi
So, this guy asks questions.....then argues about the answers? Huh?
You could possibly make it work, but you will need to modify things and will need some welding/cutting/manufacturing skills more than likely.
Old Jul 11, 2010 | 10:49 AM
03MopaRamman's Avatar
03MopaRamman
Nothin Gay about my Tow Hook set-up, it's got Stainless fasteners and Diamond Plate backing, but if you don't like the look OP you are entitled to your opinion. I'm likin the receiver Idea as a winch could be really handy up front if needed (in the Bush or no trees used with steel).
IMO HD is for HD Trucks as they got full diff up front to take the stress of a big pull if using the truck itself. I like Tow Hooks up front as a place to hook up if I need a pull.
Old Jul 11, 2010 | 11:27 AM
HammerZ71's Avatar
HammerZ71
My truck has always had a winch permanently mounted, but on my Jeep GC, because it's my daily driver, I installed a front receiver hitch ($189 shipped). I now have the versatility of carrying the winch (complete with a pair of 130 watt lights), a custom light bar I made or a shackle attached to an old, straight Reese receiver I had laying around.
Nice thing about this setup is ANY and all of the above can be inserted in the rear hitch of the Jeep or even my truck if need be...
