Power wire and Ambient Air Temp Question
Old Jul 12, 2010 | 12:41 AM
rengnath's Avatar
rengnath
Default Power wire and Ambient Air Temp Question
Hey guys,
Im posting this in the Ram section because you guys probably have more experience with the power wire. I just installed a 4.7k ohm resistor on the green wire coming from my IAT. The temp is reading cooler and it only cost me 99 cents.
Im questioning now whether or not I should install a resistor on my ambient air temperature sensor? Will the PCM recognize somethings wrong when the intake temp is lower than the ambient air temp, or is it something I shouldnt worry about. Im just seeing if the ambient air temp is something the engine uses to balance the fuel mixture.
Thanks for your help!
Old Jul 12, 2010 | 06:15 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Leave the amb temp sensor alone. It has nothing to do with the IAT. It only gives a temp readout on the OHD for you to see how hot it is outside.
Old Jul 12, 2010 | 09:42 AM
rengnath's Avatar
rengnath
Thanks,
I dont have the overhead in my truck, so I wasnt sure if that sensor served another purpose.
Old Jul 12, 2010 | 11:05 AM
brettj2408's Avatar
brettj2408
if you mess with you ambient temp sensor you will start having a/c issues and so on.
just leave it alone.
