Plastic satellite antenna is a bit lose on the roof? Issue?
Plastic satellite antenna is a bit lose on the roof. Not good check yours! The fix is
I noticed washing my truck that my satellite antenna was a bit loose on the top of my truck. The plastic piece seems to move back and forth. How would I tighten it or is the plastic square piece suppose to be loose?
The fix
To answerer my own question...Yes there is a big problem if your plastic satellite antenna on your roof is loose. It will alow water to flow freely down the antenna hole into your truck.
The fix: You must tear down the back half of your head liner and tighten the bolt pulling the antenna/rubber seal tighter to your roof. While you are there you might as well loosen the bolt so you can pull the plastic shell /rubber seal up so you can clean the surface and put some silicon grease on the rubber seal so it will stay in good shape for years.
My antenna loosened up over the last few years. It would be a good idea to check yours and make sure it is tight against the roof of your truck.
