rear spring question
Old Jul 17, 2010 | 10:23 PM
PhotogTom's Avatar
PhotogTom
Default rear spring question
I'm so full of questions tonight. I've probably used up my allotment already, but I'll inquire anyway.
One of the concerns I had when I bought this 2004 1500 2-door short bed 4X4 is that the rear springs look like they might have a bit of sag to them. Now, the rear still sits a little higher than the front, like it should as shwon below...
The problem I have, or don't have, is that it looks like the spring might have a sagging center. Here's a photo of the spring, looking at it from the rear of the truck...
Notice how it appears as if the spring rises just a bit as it goes over the axle, almost like it got bent downward on either side of the C clamp. Now, this would seem an odd place for the spring to fatigue, but stranger things have happened. (The bottom leaf is supposed to be turned downward - it is basically an overload leaf for those times when you REALLY overload the truck). It's the top 3 leaves that I'm concerned about.
Anyway, the vehicle rides well, doesn't sag, and handles decently (for a truck anyway). I'm just wondering if this spring shape is normal or if I have some fatigue. BTW, both springs are exactly the same.
Thanks, y'all!
Old Jul 17, 2010 | 10:40 PM
dirtydog's Avatar
dirtydog
Moderate User
Yeah, they don't look right.
Not a great pic but here's mine
Old Jul 17, 2010 | 10:41 PM
RedTruck-VA's Avatar
RedTruck-VA
That is how it is suppose to look.
Your truck looks stock.
Here is a picture with my truck leveled before lowering it.
Old Jul 17, 2010 | 10:44 PM
PhotogTom's Avatar
PhotogTom
I'm thinking that a little fatigue maybe. The truck towed a pretty substantial trailer in the past, with a tractor on it. I know the previous owner well - he has a nice 16-18 foot trailer, and has towed a couple of tractors with this truck.
I'm looking forward to a couple more opinions, but I suspect that I'll be replacing the leaf springs in the next 6 months or so.
Redtruck - yours looks a lot like mine. Might even be a bit lower in the back. Maybe that's the normal curve for the springs.
Old Jul 17, 2010 | 10:53 PM
RedTruck-VA
Your springs look ok, if you think it has had some heavy use. You might check the shocks.
Good luck...
Old Jul 17, 2010 | 10:56 PM
PhotogTom's Avatar
PhotogTom
Curious - did you lower by going to a "spring-under" from a "spring-over" setup?
Old Jul 17, 2010 | 11:01 PM
RedTruck-VA
Mine is lowered using a flip kit which is the standard way to drop 4 - 4.5 inches. I was just showing you the spring. I tow a MC trailer but the truck has never been used hard for hauling.
Old Jul 17, 2010 | 11:06 PM
PhotogTom's Avatar
PhotogTom
Thanks. I was just curious about the different configuration.
Old Jul 17, 2010 | 11:08 PM
dirtydog's Avatar
dirtydog
Moderate User
Big difference between your springs redtruck and the OP's which severly sag after the axle. That should not be like that. The sag probably makes such a tiny difference in ride height, but again, they shouldn't be like that. The front of the leafs look pretty bent to me.
Old Jul 17, 2010 | 11:15 PM
PhotogTom's Avatar
PhotogTom
I'd almost bet that these springs got laid up agianst the overload leaf a time or two.
I think I'll be looking at replacing them after I replace the tires. They might sit like this for years, but I'd rather have the full capacity, especially since I intend to actually haul heavy things from time to time.
