Is it worth changing my gears?
Old 07-20-2010, 03:05 PM
BadHab1t's Avatar
BadHab1t
BadHab1t is offline
i put 4.56 in my open diff an ya know what i for some reason can get both tires spinning...and i can see an improvement on my mpgs and i have a 31.5 inch tire....hmmmm all the things yall say you cant achieve....or shouldnt do....so o/p go for it if thats what you want im happy with what i did and i got mine installed for 250 and yes thats the kit at moes prolly the best price on the net....i may eventually get a auburn but i couldn't afford it at the time and i needed to do something as my bearings were shot....
Old 07-20-2010, 03:10 PM
truckin151's Avatar
truckin151
truckin151 is offline
Originally Posted by OlDirtyJohn
yup, itd be a great idea. 4.56s for 33" or bigger tires, 4.10s for smaller. it will help with acceleration, towing, and despite what most think, it WILL help your MPGs
I disagree there... 4.56's and a 31" tire is a VERY sweet combination....
Old 07-20-2010, 03:11 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
You can actually get an open diff (and even the crappy stock LSD) to lock up fairly well be applying a slight amount of brake with the gas or even using a little bit of e-brake pressure.
Something that was pretty commonly done "back in the day" but somehow got lost over the years...
Old 07-20-2010, 03:15 PM
HammerZ71's Avatar
HammerZ71
I agree with both of you. My basic rule of thumb IS 4.10s up to 33s and 4.56s for 33s and larger is perfect for a daily driver - UNLESS you tow/haul regularly or are looking for better times at the strip, then it's 4.56s or 4.88s.
Old 07-20-2010, 06:44 PM
PhotogTom's Avatar
PhotogTom
PhotogTom is offline
You may not even need that! I was doing a little "experimenting" at a stop sign and put the hammer down on my newly-acquired open-diffy truck. Lit 'em both up. Sunday, accidentally while backing up the driveway, I goosed it a little and left two short little black marks again. It seems that on these trucks, when both tires have fairly equal traction, they might be inclined to spin together.
Now, with one off the road and one on, the open differential will show off its "openness". Although, I've had much looser differentials including (unfortunately) the front diffy in my Escape. It takes nothing to get a one-wheel spin out of that car, especially on a loose surface. With the truck, it seems to act a little like an LSD even though it isn't.
Strange...
Old 07-20-2010, 07:13 PM
RedTruck-VA's Avatar
RedTruck-VA
RedTruck-VA is offline
Originally Posted by badblackram06
Nice. I was looking at some 4.56s. would this be what i need?
http://moesperformance.com/index.php...oducts_id=1134
I bought a version of this kit from Moe's http://moesperformance.com/index.php...oducts_id=9046
Only wish I had gone with 4:56 instead of 4:10's.
Good luck...
Quick Reply: Is it worth changing my gears?
