[VIDEO] DIY PowerWire
Old Oct 21, 2010 | 02:29 PM
  #41
weedahoe's Avatar
weedahoe
Hall of Fame Member
I have checked many different vendors and unless you are going to do a bulk order from China, the answer is no.
Old Oct 27, 2010 | 07:51 PM
  #42
hemiracermech's Avatar
hemiracermech
Have you used a different ohm resister? Is their any difference in this mod and the power wire?
Old Oct 27, 2010 | 10:06 PM
  #43
T-Muns's Avatar
T-Muns
Bummer...oh well, I'll probably just go ahead with the mod then.
Old Oct 28, 2010 | 08:20 AM
  #44
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yes I have and 4.7 is the highest you can go before the PCM starts to override it and compensate.
And what do you mean is there any difference between this mod and the power wire? Did you rear the title? THIS mod IS the Power wire.
Old Oct 28, 2010 | 08:36 AM
  #45
hemiracermech
I didnt know if there is something else thats in the power wire had then the mod. They are charging $40 for a plug and play and all it has is a resister in it?
Old Oct 28, 2010 | 08:53 AM
  #46
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yep, a authentic PW is a 4.7k ohm resistor in nice wire with heat shrink and fire resistant loom with nice PnP ends on it. Guys who buy it are those who dont know better or like the simplicity of it being PnP with no wires to cut or not being mechanically enough to make one.
Old Oct 28, 2010 | 09:16 AM
  #47
hemiracermech
Ok, thanks. Its going to be to easy to make. Thanks for the vid, also
Old Nov 11, 2010 | 07:39 PM
  #48
AZZO540's Avatar
AZZO540
weed made the power wire and installed it watched the temp drop 20 degrees to.
thanks the vid could have done it otherwise.
Size:  46.0 KB Name:  2010-11-11154216.jpg
Size:  46.8 KB Name:  2010-11-11154654.jpg
Size:  45.2 KB Name:  2010-11-11161815.jpg
Old Nov 11, 2010 | 11:16 PM
  #49
OklaHemi's Avatar
OklaHemi
nice vid weed.
Old Nov 11, 2010 | 11:20 PM
  #50
OklaHemi's Avatar
OklaHemi
i have never heard of the sonnax thing. weed is it worth it in your professional eyes
