In getting repaired
Old Jul 23, 2010 | 10:57 AM
navyjoker2000's Avatar
navyjoker2000
Default In getting repaired
Ok, check engine lights on, popped codes 0315 and 0016. They are for crankshaft and camshaft sensors I believe, but the dealership took the cylinder heads off. Hmm, truck was misfiring, and lost a lot of power. It is a 2005 Ram 1500 Quad Cab with the Hemi. Any ideas anyone? Been losing coolant and truck has been getting hot easy. My guess and hopefully not is a head gasket. If anybody can think of anything else let me know. This sucks.
Old Jul 23, 2010 | 11:09 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Can i assume you have a 4.7?
You best hope is that it is a bad head gasket and not a cracked head. If you are loosing coolant and misfiring, well, those two just go hand in hand with one another.
Old Jul 23, 2010 | 11:14 AM
navyjoker2000
No I have the 5.7 Hemi.
Old Jul 23, 2010 | 11:35 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Thats better but if you are loosing coolant and over heating then you still gasket/head issues. If you were not loosing coolant then it might be a different story.
Where are you located? Are you mechanically inclined?
Old Jul 23, 2010 | 11:53 AM
navyjoker2000
Stationed in Central Cali, and yes mechanically inclined.
Old Jul 29, 2010 | 10:29 AM
navyjoker2000
Here is an update. They said it was valve pitting. The cylinder heads were good. Still don't know why the valves would pit though
Old Jul 29, 2010 | 01:45 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ask to see the valves they pull out.
Old Aug 20, 2010 | 03:41 PM
navyjoker2000
Ok, I looked at all the valves. They didn't look to bad. But the dealer machined the heads, and the valves, and put them back on. I went on leave while they did this, and picked it up when I got back. Well I drove it for about 25 miles and it started to misfire again, with no check engine light. So I took it back in and now they are saying it is the intake manifold. I have no idea. Anybody else have any?
Old Aug 20, 2010 | 04:36 PM
Duroc's Avatar
Duroc
Still back to square one, head gasket or cracked head.
Old Aug 20, 2010 | 05:02 PM
navyjoker2000
Well when they had the heads off to have them machined they did pressure checks, looked for cracks and replaced the head gasket when they re-installed them.
