180 degree therm. question for 4.7 owners
Old Jul 25, 2010 | 06:09 PM
nitforfun's Avatar
nitforfun
Default 180 degree therm. question for 4.7 owners
hello all
I'm looking at getting a 180 deg. thermostat for my 2006 ram 4.7 and I have a question about the bleeder hole that is on the stock thermostat.
the jet 180 doesn't look as though it has one so my question is is this going to cause any problems
Thanks for looking
Old Jul 25, 2010 | 06:47 PM
chambers's Avatar
chambers
Do you already have the jet, there is a cheaper alternative you should be able to get locally. If you've already got it just drill a bleed hole in it matching up to the stock one.
Old Jul 25, 2010 | 07:51 PM
BadHab1t's Avatar
BadHab1t
i agree with chambers....
Old Jul 26, 2010 | 01:18 PM
smoker911's Avatar
smoker911
Question 180 therm ?????
Hey Chambers....what is the alternative that u r talking about? I want to get the 180 therm ,So let me in on the deal
Old Jul 26, 2010 | 03:43 PM
BadHab1t's Avatar
BadHab1t
call napa and ask for a 180* t-stat for your yr of truck...
Old Jul 26, 2010 | 08:23 PM
chambers's Avatar
chambers
It's the stant 45358, you can get it at napa or advance. You should drill a bleed hole and make a notch w/ a file in the new t-stat to match the oem one. The stant is spec'd for 2002 5.9 gas engine but it works for the 3.7 and 4.7 from 02-07.
Old Jul 31, 2010 | 05:18 PM
nitforfun's Avatar
nitforfun
Well i got the thermostat that was suggested by Chambers and it works well so far
i haven't even recieved the one from Moe's performance yet to send it back
but the Stant was just under $10 with tax
thanks for the help
I will be sending the jet thermostat back
Old Jul 31, 2010 | 05:57 PM
chambers's Avatar
chambers
I've got the same one in my 3.7, I made sure it opened by dropping it in some boiling water before I put it in. I found it would work searching on here and dodge talk looking for a cheap 180 I could get locally. Glad I could help out.
Old Aug 1, 2010 | 12:48 PM
04_ramslt's Avatar
04_ramslt
What made you guys want to use a 180*??
Old Aug 1, 2010 | 01:50 PM
chambers's Avatar
chambers
Sean aka hemifever recommended I get one to help prevent knocking/pining w/ the custom tuning.
